[Armbian build PR] - Debian bookworm desktops
Complete Desktop updates for bookworm. This update follows the debian approach of desktops following the task-(desktopname)-desktop install . I also had to split the skel for each desktop to keep installs cleaner as only the files for that desktop get installed and not files for other desktops not in use on the build. skel.all skel.(desktopname).
I have done a complete update to the appsgroups and we moved printing and filesharing support to the appgroups to make things cleaaner in the long run.
a few new appgroupds added and apps added and removed.
everything done . was done with feedback from users.
Note : At this point desktops imgs will be bigger then the 8g sd card and shold be moved to 16 gig sd cards by default.
I ran multi builds to confirm everything builds and works as it should out of the box.
View the full article
