Dantes Posted June 14, 2023 Share Posted June 14, 2023 (edited) I've been following this thread: https://forum.openwrt.org/t/nanopi-r6s-linux-6-3-arm-soc-updates/153072/14 downloaded the latest version. Decided to do some experimenting and found out that they use u-boot 2023.04. And after some experimenting I found out that it works with Armbian when I flash it to the internal storage. U-Boot 2017.09-armbian (Apr 25 2023 - 04:20:41 +0000) U-Boot SPL 2023.04-OpenWrt-r0-e283eb2 (Jun 12 2023 - 00:36:27 +0000) Whats the reason the armbian u-boot is so far behind ? (i know its WIP, just asking) Edited June 14, 2023 by Dantes typo 0 Quote Link to comment Share on other sites More sharing options...
Efe Çetin Posted June 14, 2023 Share Posted June 14, 2023 It's because of we are using legacy uboot There also some missing features and bugs on upstream uboot. We might use it as edge in the future 0 Quote Link to comment Share on other sites More sharing options...
Dantes Posted June 14, 2023 Author Share Posted June 14, 2023 Disclaimer: For people reading this thread: this is what I did, unless you know exactly what you are doing, don't try this. I extracted the bootloader from the Armbian Image and hurled it through binwalk and then packed it to get some indication of its entropy: # xzcat Armbian_23.5.1_Nanopi-r6s_jammy_legacy_5.10.160_minimal.img.xz | head -c $((16*1024*1024)) > bootloader # ls -l bootloader -rw-rw-r-- 1 test test 16777216 Jun 14 bootloader # binwalk bootloader DECIMAL HEXADECIMAL DESCRIPTION -------------------------------------------------------------------------------- 244504 0x3BB18 CRC32 polynomial table, little endian 320368 0x4E370 Flattened device tree, size: 5186 bytes, version: 17 8388608 0x800000 Flattened device tree, size: 2255 bytes, version: 17 9186092 0x8C2B2C CRC32 polynomial table, little endian 9248112 0x8D1D70 Android bootimg, kernel size: 1919249152 bytes, kernel addr: 0x5F6C656E, ramdisk size: 1919181921 bytes, ramdisk addr: 0x5700635F, product name: "" 9799680 0x958800 Flattened device tree, size: 9761 bytes, version: 17 # gzip -k bootloader # ls -l bootloader.gz -rw-rw-r-- 1 test test 737185 Jun 14 bootloader.gz # Then did the same for the OpenwRT Image: # zcat openwrt-rockchip-armv8-friendlyelec_nanopi-r6c-squashfs-sysupgrade.img.gz | head -c$((16*1024*1024)) > openwrt_bootloader # ls -l openwrt_bootloader -rw-rw-r-- 1 test test 16777216 Jun 14 openwrt_bootloader # binwalk openwrt_bootloader DECIMAL HEXADECIMAL DESCRIPTION -------------------------------------------------------------------------------- 199408 0x30AF0 Flattened device tree, size: 4419 bytes, version: 17 8388608 0x800000 Flattened device tree, size: 22528 bytes, version: 17 9421824 0x8FC400 Flattened device tree, size: 47104 bytes, version: 17 # gzip -k openwrt_bootloader # ls -l openwrt_bootloader.gz -rw-rw-r-- 1 test test 572342 Jun 14 openwrt_bootloader.gz # The armbian bootloader seems to have a false positive or some old garbage afaict in this particular image, which is common in a WIP. Then installed the bootloader: # sgdisk --backup=partition-table.original /dev/mmcblk2 # dd if=openwrt_bootloader bs=16M count=1 of=/dev/mmcblk2 1+0 records in 1+0 records out 16777216 bytes (17 MB, 16 MiB) copied, 0,0489076 s, 343 MB/s # sgdisk --load-backup=partition-table.original /dev/mmcblk2 Warning: The kernel is still using the old partition table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8) The operation has completed successfully. # reboot Now running u-boot 2023.04 0 Quote Link to comment Share on other sites More sharing options...
