RSS Bot Posted June 16, 2023 Posted June 16, 2023 Description Since of historical reasons script armbian-install is still creating a log file with name /var/log/nand-sata-install.log as well as using other artifacts from folder /usr/lib/nand-sata-install. I would like to align those names to comply with the original script name having been run: If run as nand-sata-install => create /var/log/nand-sata-install.log, lookup artifacts in /usr/lib/nand-sata-install If run as armbian-install => create /var/log/armbian-install.log, lookup artifacts in /usr/lib/armbian-install To achieve 2. I did: rename folder packages/bsp/common/usr/lib/nand-sata-install -> packages/bsp/common/usr/lib/armbian-install - since this is now the most likely current one. create a symbolic link packages/bsp/common/usr/lib/nand-sata-install linking to packages/bsp/common/usr/lib/armbian-install for backward compatibility. How Has This Been Tested? Tested on a board (Cubietruck) installed. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings View the full article
