RSS Bot Posted June 17, 2023 Posted June 17, 2023 Description This PR enabled USB port present on the expansion board for the OrangePi Zero 2 sbc. This change applies to the current current variant of the OS for this board (Kernel 6.1.y). (Similar PR for 6.2.y kernel here: #5344) How Has This Been Tested? Requirements: Any USB stick with basic file system present (eg. exFAT) and some files / folders on it Logged in as root or as a user with sudo priviledges [x] Test A: make sure the change does not break the board when used WITHOUT the expansion board Boot up the board Check whether the base USB port still works correctly lsusb shows the USB stick when plugged into the port mount /dev/sda1 /media/<mountpoint> is able to mount the USB stick plugged into the port [x] Test B: check whether the ports work when expansion board is plugged in Plug a USB stick into one of the additional ports Check whether the tested port works correctly lsusb shows the USB stick when plugged into the port mount /dev/sda1 /media/<mountpoint> is able to mount the USB stick plugged into the port ls /media/<mountpoint> properly enumerates files / folders on the stick umount /media/<mountpoint> is able to unmount the USB stick Repeat for the other port on the expansion board Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
