RSS Bot Posted June 20, 2023 Posted June 20, 2023 Description I just move config/kernel/linux-rockchip-rk3588-legacy.config to config/kernel/linux-rk35xx-legacy.config, and make them share the same family rk35xx. Now rk356x will use the same kernel rk3588 legacy is using. I tested the new kernel on my rock3a, working well. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Build legacy kernel of rock3a and rock5b, same result. [x] New kernel works on rock3a. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
