RSS Bot Posted June 21, 2023 Posted June 21, 2023 Description Instead of requesting to install gcc-or1k-bin package unconditionally, request it only when building images with crust support. Also consolidated crust related configuration into a separate file. Jira reference number AR-1786 How Has This Been Tested? [X] ./compile.sh DOCKER_ARMBIAN_BASE_IMAGE="debian:bullseye" BOARD=nanopineo works as it doesn't need crust support [X] ./compile.sh DOCKER_ARMBIAN_BASE_IMAGE="debian:bullseye" BOARD=nanopiduo2 fails as it bullseye doesn't include gcc-or1k-bin package and hence reported as unsupported system [X] ./compile.sh BOARD=nanopiduo2 works as default release is jammy that has the required package Checklist: [X] My code follows the style guidelines of this project [X] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [ ] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
