RSS Bot Posted July 4, 2023 Posted July 4, 2023 Description Now NVME has the highest boot priority in uboot. But I think SD card should have higher boot priority than NVME SSD because SD card is much easier to plug in/out than NVME SSD. This patch is from https://github.com/radxa/u-boot/pull/25. We can add it to armbian whe it's not merged upstream. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] uboot build successfully [x] Armbian on SD card boots when NVME SSD is installed. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
