nickeh Posted November 19, 2016 Posted November 19, 2016 Hi, I got my Zero today and installed the legacy jessie server. I need X (for one app) so I followed the same path as I did on my Raspberry Pi running Raspbian lite. sudo apt-get install --no-install-recommends xserver-xorg sudo apt-get install --no-install-recommends xinit sudo apt-get install xfce4 xfce4-terminal sudo apt-get install lightdm Should TV-OUT (pin 9 (and GND on pin 2) on 1x13 header) work as I do not get anything on my composite monitor? I looked in /boot/boot.cmd and it says setenv disp_mode "1920x1080p60" which is not compatible with a composite signal. I tried to alter it to 720x576i50 but no luck. I just wanted the TV-OUT to see that everything was working and that I really have a graphical desktop. I'm planning on using only X11vnc but it seems that the graphical desktop is not there because I can not get X11vnc to start. *** x11vnc was unable to open the X DISPLAY: ":0", it cannot continue. It seems like the X server is started and lightdm but I don't have enough experience to find what is wrong root 673 0.0 1.8 29544 9376 tty7 Ss+ 10:48 0:00 /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch root 702 0.0 0.6 27796 3448 ? Sl 10:48 0:00 lightdm --session-child 17 20 lightdm 708 0.0 0.2 4000 1488 ? Ss 10:48 0:00 /lib/systemd/systemd --user lightdm 709 0.0 0.2 5748 1144 ? S 10:48 0:00 (sd-pam) lightdm 711 0.1 2.2 35420 11476 ? Ssl 10:48 0:01 /usr/sbin/lightdm-gtk-greeter lightdm 716 0.0 0.0 3108 492 ? S 10:48 0:00 /usr/bin/dbus-launch --autolaunch a6959a1b583340b7a8741924192b921b --binary-syntax --close-stderr lightdm 717 0.0 0.1 4572 856 ? Ss 10:48 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session Any ideas? Thanks in advance!
iLoveDevBoards Posted December 6, 2016 Posted December 6, 2016 HI There! I don't know if you still need the information for the tv out but here it is anyway: Fetch your self a composite cable r/y/w color doesnt really matter. Type in term Sudo nano /etc/modules simply add tv to the last line of the file, exit and save ofcourse Then type in (Might need to reboot first) Connect the cable to pin 2(ground) and pin 9(signal) (pin count starts from where the little white triangle is located) connect the cable to the yellow video port on your tv then type in sudo modprobe tv if everything went right you should have video output on your tv now that's what i got:D Good luck and most important of all Have fun!
nartu Posted January 2, 2017 Posted January 2, 2017 Thank you iLoveDevBoards... I just got my orange pi zéro working!
