[Armbian build PR] - Remove plymouth package if its not needed
Description
When a hardware doesn't have video out, we set PLYMOUTH to no to determine if we our plymouth theme needs to be installed. But on the other hand, for standard images, even when PLYMOUTH is set to no we leave plymouth installed in the final image.
This PR changes the same to make sure plymouth is not installed when its not needed. Reduces little bit of boot time and helps keep u-boot logs intact on serial console.
How Has This Been Tested?
  • [X] Built a image for nanopiduo2 as it doesn't have video output and made sure plymouth is not installed in standard image
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
