[Armbian build PR] - rtw88: sdio: `honor the host max_req_size in the rx path`
Use multiple consecutive reads in rtw_sdio_read_port() to limit the number of bytes which are copied by the host from the card in one MMC/SDIO transfer. This allows receiving a buffer that's larger than the hosts max_req_size (number of bytes which can be transferred in one MMC/SDIO transfer). As a result of this the skb_over_panic error is gone as the rtw88 driver is now able to receive more than 1536 bytes from the card (either because the incoming packet is larger than that or because multiple packets have been aggregated).
Disabled: 001-revert-rtw88-sdio-size-and-timout-to-rfc-v1.patch
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
