I need set the PC1 pin as output on a device driver using the new gpiod_export() method.
What argument should i pass on the gpiod_get function?
    struct gpio_desc *gpio;
    gpio = gpiod_get(NULL, "PC1", GPIOD_OUT_HIGH);
    if (IS_ERR(gpio)) {
        printk("Failed to get GPIO: \n");
        return PTR_ERR(gpio);
    // Export the GPIO
    ret = gpiod_export(gpio, false);
    if (ret) {
        pr_err("Failed to export GPIO: %d\n", ret);
        return ret;
    // Set the direction of the GPIO
    ret = gpiod_direction_output(gpio, 1);
    if (ret) {
        pr_err("Failed to set GPIO direction: %d\n", ret);
        return ret;
Armbian 23.8
Best regards
