Bluetooth not working with orange-pi-zero-plus-2-h3
Mark Orr
I just installed the image located here and am unable to get a bluetooth keyboard and mouse to connect.
https://www.armbian.com/orange-pi-zero-plus-2-h3/
And used armbian-config -> Network -> Enable bluetooth.
Here's the output of some common debugging commands I found in the forums.
root@orangepizeroplus2-h3:~# lsusb
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@orangepizeroplus2-h3:~# rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
root@orangepizeroplus2-h3:~# sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2023-07-11 21:43:39 EDT; 21min ago
       Docs: man:bluetoothd(8)
   Main PID: 2945 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 828)
     Memory: 424.0K
        CPU: 283ms
     CGroup: /system.slice/bluetooth.service
             └─2945 /usr/lib/bluetooth/bluetoothd
Jul 11 21:43:39 orangepizeroplus2-h3 systemd[1]: Starting Bluetooth service...
Jul 11 21:43:39 orangepizeroplus2-h3 bluetoothd[2945]: Bluetooth daemon 5.64
Jul 11 21:43:39 orangepizeroplus2-h3 systemd[1]: Started Bluetooth service.
Jul 11 21:43:39 orangepizeroplus2-h3 bluetoothd[2945]: Starting SDP server
Jul 11 21:43:39 orangepizeroplus2-h3 bluetoothd[2945]: Bluetooth management interface 1.22 initialized
root@orangepizeroplus2-h3:~#  hcitool scan
Device is not available: No such device
I also ran
armbianmonitor -U > monitor.txt
The results of which are attached to this message.
It seems like the bluetooth service comes up, but it doesn't see any bluetooth devices.
Can anyone point me in the right direction?
monitor.txt
