on my Pinebook Pro with Armbian, I would like to use AesCrypt like on all my other Linux and Windows and Android systems, but here on Armbian, I need some support...
- AesCrypt seems not to be available as deb package in Armbian and also Debian repos, right?
- install AesCrypt directly from AesCrypt website as deb package with gdebi doesn"t work, guess because it is for x86 only
- so I would like to make use of pyAesCryt as module in my Python script
- the way as I know it from Archlinux and Manjaro,
pip install pyAesCrypt
 does not work, get a message "environment is externally managed, not Debian-packaged software has to be installed via pipx"
(I don't know what "externally managed environment" means, seems to special in Debian / Armbian. Is there a good documentation?)
- now,
pipx install pyAesCryt
installs pyAesCryt sucessfully, and I also did the recommended
pipx ensurepath
- but, pyAesCrypt is not listed as installed module and
- with adapted calls in my methods (aescrypt to pyaescrypt) and an module import
import pyAesCrypt
after starting the script, when it comes to the call, an error message says " no such module"
Any help would be much appreciated!
