[Armbian build PR] - Allwinner: current, edge: Bump kernel and u-boot
Description
Bumped kernel versions
Current: 6.1.38 -> 6.1.39 Edge: 6.4.2 -> 6.4.4
  • Modified thermal-sun8i-Be-loud-when-probe-fails.patch to fix patch application failure
  • Disabled drm-sun4i-Fix-wrong-location-of-clk_prepare_enable.patch to fix patch failure and as its not needed after the upstream change
  • Rest of the disabled patches for 6.4.4 are upstreamed
U-boot: 2023.07 -> 2023.07.02. This is very trivial bump. It only removes the -rc6 extra version from the Makefile which was not removed when 2023.07 was released.
Jira reference number [AR-9999]
How Has This Been Tested?
  • [X] Booted current and edge images on Orange Pi Prime (sun50i H5)
  • [X] Booted current and edge images on NanoPi Duo2 (sun8i H3)
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
  • [X] Any dependent changes have been merged and published in downstream modules
View the full article
