RSS Bot Posted July 20, 2023 Posted July 20, 2023 Description When creating builds with CRYPTROOT_ENABLE=yes there were issues with package caching and intermittent issue with root partition not getting detected that was breaking the build. Also the functionality was broken because of /dev/mapper/armbian-root not being available during initramfs generation and there was a possibility of functionality being broken due to use of incorrect cached initrd file. This PR fixes the same. Jira reference number AR-1799 How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [X] Created build for NanoPi Duo2 with CRYPTROOT_PASSPHRASE=crypt_pass CRYPTROOT_ENABLE=yes CRYPTROOT_SSH_UNLOCK=no and made sure that I was able to unlock the encrypted rootfs with passphrase [ ] Will test if ssh unlock works on Orange Pi Prime and then will remove the wip status Checklist: [X] My code follows the style guidelines of this project [X] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
