Zandr Posted July 21, 2023 Posted July 21, 2023 I'm attempting an install to the eMMC on a CM4 (mounted on an Axzez Interceptor) using armbian-install. I've booted Armbian 23.5 Jammy CLI from USB, and armbian-install runs fine, (boot from eMMC, system on eMMC) After transferring the rootfs I get the "Cleaning up ... Almost done." message, and then the following: Error while creating U-Boot loader image with mkimage Error: no u-boot package found, exiting I've run a full update / upgrade and installed armbian-config with no change. What's missing here? 0 Quote
