John Glasson Posted July 24, 2023 Posted July 24, 2023 I plan to upgrade my NVMe memory. I currently boot off it - I set this up using the Armbian installer. Before doing the upgrade I'd like to know that I can boot off my SD card, should anything go wrong with the upgrade. But I'm unsure how to disable the NVMe boot sequence (which I think is SPI flash --> eMMC/mmcboot --> NVMe). If I insert my Armbian SD card, the system doesn't start. I've tried shorting pins 23/25 to disable the SPI flash but this has no effect. I am assuming that I can complete the upgrade by amending armbianEnv.txt to make the 'rootdev=UUID' line point to the new NVMe's UID? Is there a known solution to my query? 0 Quote
