Adding custom driver to Armbian
Mathias Nichele
Hello,
I'm currently working on integrating a custom-made driver into my Armbian build, but I'm facing some challenges. I've researched the process and found that it should be done through the kernel configuration. However, despite my efforts, I can't seem to find any option that allows me to add a custom driver.
I've attempted placing the .ko file in a /driver folder, that I created within the source, as well as in the kernel/ folder under userpatches/, but unfortunately, it hasn't worked.
I'm seeking guidance on whether it's possible to add a custom driver to an Armbian build and, if so, I'd greatly appreciate any insights or step-by-step instructions on how to achieve this.
I also want to add some folders and files to the build, although I think this is done via the 'customize-image.sh' script, but any confirmation would be apreciated.
Thank you for your time and assistance.
Edited by Mathias Nichele
