[Armbian build PR] - kernel:sunxi: Add tve encoder for H5 boards as well
Description
Found we had cvbs support for allwinner H3 for current kernel. It had bits to make it working for H5 as well with only thing missing was the overlay to enable the it. Hence added the overlay for H5. Also as the patch was missing in edge kernel, added the same.
How Has This Been Tested?
  • [X] Created a server image for OrangePi Prime and attached a CVBS/AV display to it. The console was also shown on the AV monitor.
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
