Under kernel 4.9, using a usb3.0 to Gigabit interface with RTL8153b card, the upstream and downstream speed can reach Gigabit.
But with kernel5.10, the speed can't reach gigabit, and the driver file has been changed to the latest version, but still no effect.
kernel5.10 Speed measurement
root@orangepi3-lts:~# iperf3 -c 192.168.3.201
Connecting to host 192.168.3.201, port 5201
[ 5] local 192.168.3.146 port 44376 connected to 192.168.3.201 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 24.8 MBytes 208 Mbits/sec 0 147 KBytes
[ 5] 1.00-2.00 sec 23.5 MBytes 198 Mbits/sec 0 147 KBytes
[ 5] 2.00-3.00 sec 23.5 MBytes 197 Mbits/sec 0 147 KBytes
[ 5] 3.00-3.15 sec 3.66 MBytes 202 Mbits/sec 0 147 KBytes
root@orangepi3-lts:~# iperf3 -c 192.168.3.201 -R
Reverse mode, remote host 192.168.3.201 is sending
[ 5] local 192.168.3.146 port 44380 connected to 192.168.3.201 port 5201
[ 5] 0.00-1.00 sec 47.5 MBytes 399 Mbits/sec
[ 5] 1.00-2.00 sec 48.4 MBytes 406 Mbits/sec
[ 5] 2.00-2.99 sec 48.1 MBytes 406 Mbits/sec
root@orangepi3-lts:~# lsusb -t
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
Edited by sakesm
Attempt to use a hub to plug into USB 3.0, and then plug the RTL8153b USB to Gigabit Ethernet port into the hub, but unexpectedly discover that the speed can reach Gigabit.
    |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
