Jae Woo Song Posted November 23, 2016 Posted November 23, 2016 Hi, I am using orangepi+ with armbin debian jessie 5.20. I want to use softAp. orangepi+ have rtl8189etv, but when i am using Hostapd with isc-dhcp-server,if i enter to command line "iwlist wlan0 scan " , i can see kernel panic on screen. when i use bluetooth dongle (rtl8192cus), i can use hostapd and get scanlist.. rtl8189etv is not supported softAP?... or other problem? thanks...
Jae Woo Song Posted November 23, 2016 Author Posted November 23, 2016 i remove hostapd and install hostapd-realtek #apt-get remove --purge hostapd #apt-get install hostapd-realtek #nano /etc/hostapd.conf ctrl_interface=/var/run/hostapdctrl_interface_group=0macaddr_acl=0auth_algs=1ignore_broadcast_ssid=0driver=rtl871xdrvinterface=wlan0hw_mode=gchannel=6ssid=TEST_AP # hostapd -dd /etc/hostapd.confrandom: Trying to read entropy from /dev/randomConfiguration file: /etc/hostapd.confctrl_interface_group=0drv->ifindex=4l2_sock_recv==l2_sock_xmit=0x0xb82f96e0BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=0 dBmAllowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=0 dBmAllowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=52 freq=5260 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=56 freq=5280 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=60 freq=5300 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=64 freq=5320 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=100 freq=5500 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=104 freq=5520 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=108 freq=5540 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=112 freq=5560 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=116 freq=5580 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=120 freq=5600 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=124 freq=5620 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=128 freq=5640 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=132 freq=5660 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=136 freq=5680 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=140 freq=5700 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=0 dBmAllowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=0 dBmCompleting interface initializationMode: IEEE 802.11g Channel: 6 Frequency: 2437 MHzDFS 0 channels required radar detectionRATE[0] rate=10 flags=0x1RATE[1] rate=20 flags=0x1RATE[2] rate=55 flags=0x1RATE[3] rate=110 flags=0x1RATE[4] rate=60 flags=0x0RATE[5] rate=90 flags=0x0RATE[6] rate=120 flags=0x0RATE[7] rate=180 flags=0x0RATE[8] rate=240 flags=0x0RATE[9] rate=360 flags=0x0RATE[10] rate=480 flags=0x0RATE[11] rate=540 flags=0x0hostapd_setup_bss(hapd=0xb82fb498 (wlan0), first=1)wlan0: Flushing old station entrieswlan0: Deauthenticate all stations+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2rtl871x_set_key_opsrtl871x_set_key_opsrtl871x_set_key_opsrtl871x_set_key_opsUsing interface wlan0 with hwaddr 00:6c:fd:26:40:ed and ssid "TEST_AP"rtl871x_set_wps_assoc_resp_iertl871x_set_wps_beacon_iertl871x_set_wps_probe_resp_iertl871x_set_beacon_opsrtl871x_set_hidden_ssid_opsioctl[RTL_IOCTL_HOSTAPD]: Invalid argumentwlan0: interface state UNINITIALIZED->ENABLEDwlan0: AP-ENABLEDwlan0: Setup of interface done.ctrl_iface not configured!random: Got 20/20 bytes from /dev/random #ps ax | grep [h]ostapd | grep -v grep 1668 pts/0 S+ 0:00 hostapd -dd /etc/hostapd.conf And finally, #sudo iwlist wlan0 scan Message from syslogd@hanamicronGw at Nov 23 19:09:45 ... kernel:[ 689.779053] sunxi oops: enable sdcard JTAG interfacewlan0 Scan completed : Cell 01 - Address: 00:27:1C:3C:52:DA ESSID:"miniWiFi_3C2D" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.412 GHz (Channel 1) Encryption key:on Bit Rates:72 Mb/s Extra:wpa_ie=dd1a0050f20101000050f20202000050f2020050f20401000050f202 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK IE: Unknown: DD8D0050F204104A0001101044000102103B000103104700106304125310192006122800271C3C52D91021000B4D65726375727920436F2E1023000A4B4D30312D32313246501024000641505F31314E104200114D435253323031323132303030303031301054000800060050F20400011011000A4B4D30312D323132465010080002268E1049000600372A000120 Quality=100/100 Signal level=74/100 Extra:fm=0003 Cell 02 - Address: A4:6C:2A:A8:64:62 ESSID:"BeaconZone" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.412 GHz (Channel 1) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=100/100 Signal level=100/100 Extra:fm=0003 Cell 03 - Address: A4:6C:2A:A8:64:61 ESSID:"IotGuest" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.412 GHz (Channel 1) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=100/100 Signal level=100/100 Extra:fm=0003 Cell 04 - Address: A4:6C:2A:A8:64:60 ESSID:"" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.412 GHz (Channel 1) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=0/100 Signal level=100/100 Extra:fm=0001 Cell 05 - Address: 00:6C:FD:26:60:EA ESSID:"AniMonitorV04" Protocol:IEEE 802.11bg Mode:Master Frequency:2.437 GHz (Channel 6) Encryption key:on Bit Rates:54 Mb/s Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=20/100 Signal level=90/100 Extra:fm=0003 Cell 06 - Address: 24:D1:3F:10:2A:FD ESSID:"mLTE7679" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.437 GHz (Channel 6) Encryption key:on Bit Rates:72 Mb/s Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=36/100 Signal level=72/100 Extra:fm=0003 Cell 07 - Address: 90:9F:33:EE:B6:9F ESSID:"HANAMICRON_C57E" Protocol:IEEE 802.11bg Mode:Master Frequency:2.437 GHz (Channel 6) Encryption key:on Bit Rates:54 Mb/s Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=48/100 Signal level=88/100 Extra:fm=0003 Cell 08 - Address: 00:26:66:D5:22:64 ESSID:"" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.427 GHz (Channel 4) Encryption key:on Bit Rates:300 Mb/s Extra:wpa_ie=dd160050f20101000050f20401000050f20401000050f202 IE: WPA Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD0E0050F204104A0001101044000102 Quality=100/100 Signal level=84/100 Extra:fm=0001 Cell 09 - Address: 80:E0:1D:D7:C3:00 ESSID:"" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.437 GHz (Channel 6) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=100/100 Signal level=56/100 Extra:fm=0001 Cell 10 - Address: 80:E0:1D:D7:C3:02 ESSID:"BeaconZone" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.437 GHz (Channel 6) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=0/100 Signal level=56/100 Extra:fm=0003 Cell 11 - Address: 90:9F:33:A9:1D:7E ESSID:"Device_Test" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.452 GHz (Channel 9) Encryption key:on Bit Rates:300 Mb/s Extra:rsn_ie=30140100000fac040100000fac040100000fac020c00 IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD740050F204104A0001101044000102103B000103104700100000000000000000000000000000000010210006697054494D4510230008697054494D4541501024000A313233343536373839301042000232321054000800060050F204000110110008697054494D454150100800020084103C000103 Quality=36/100 Signal level=96/100 Extra:fm=0003 Cell 12 - Address: 90:9F:33:EC:74:B8 ESSID:"HanamicronGW_143D" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.452 GHz (Channel 9) Encryption key:on Bit Rates:72 Mb/s Extra:wpa_ie=dd1a0050f20101000050f20202000050f2040050f20201000050f202 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : CCMP TKIP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=100/100 Signal level=100/100 Extra:fm=0003 Cell 13 - Address: 80:E0:1D:BD:45:92 ESSID:"BeaconZone" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=48/100 Signal level=70/100 Extra:fm=0003 Cell 14 - Address: 80:E0:1D:BD:45:91 ESSID:"IotGuest" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=36/100 Signal level=70/100 Extra:fm=0003 Cell 15 - Address: 64:E5:99:4C:2E:B0 ESSID:"Gateway2.5_TestAp" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:300 Mb/s Extra:wpa_ie=dd160050f20101000050f20401000050f20401000050f202 IE: WPA Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : CCMP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK IE: Unknown: DD9E0050F204104A0001101044000102103B0001031047001063041253101920061228AABBCCDDEEFF1021001B5265616C74656B2053656D69636F6E647563746F7220436F72702E1023000752544C387878781024000D45562D323030392D30322D30361042000F3132333435363738393031323334371054000800060050F2040001101100135265616C74656B20576972656C657373204150100800020080 Quality=20/100 Signal level=100/100 Extra:fm=0003 Cell 16 - Address: 80:E0:1D:BD:45:90 ESSID:"" Protocol:IEEE 802.11bgn Mode:Master Frequency:2.462 GHz (Channel 11) Encryption key:on Bit Rates:144 Mb/s Extra:wpa_ie=dd1c0050f20101000050f20202000050f2020050f20401000050f2020000 IE: WPA Version 1 Group Cipher : TKIP Pairwise Ciphers (2) : TKIP CCMP Authentication Suites (1) : PSK Extra: IE: IEEE 802.11i/WPA2 Version 1 Group Cipher : TKIP Pairwise Ciphers (1) : CCMP Authentication Suites (1) : PSK Quality=0/100 Signal level=74/100 Extra:fm=0001 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] sunxi oops: cpu frequency: 480 MHz Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] sunxi oops: ddr frequency: 672 MHz Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] sunxi oops: gpu frequency: 105 MHz Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] sunxi oops: cpu temperature: 53 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] Internal error: Oops: 17 [#1] PREEMPT SMP ARM Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] Process RTW_CMD_THREAD (pid: 469, stack limit = 0xee2f42f8) Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] Stack: (0xee2f5f30 to 0xee2f6000) Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5f20: f01e85e0 f01e85e8 bf0b74b0 ee464200 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5f40: f01e7000 f01e85e0 ee2f5f74 ee2f5f58 bf025870 bf016ba4 ee061540 f01e7000 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5f60: f01e85b8 f01e85e0 ee2f5fb4 ee2f5f78 bf004b5c bf0257f4 00000000 f01e85cc Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5f80: f01e8610 ee464200 00000013 ee2c79d4 f01e7000 bf0048e4 00000013 00000000 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5fa0: 00000000 00000000 ee2f5ff4 ee2f5fb8 c0049c58 bf0048f0 00000000 00000000 Message from syslogd@hanamicronGw at Nov 23 19:09:47 ... kernel:[ 689.789027] 5fc0: f01e7000 00000001 00000000 00000000 ee2f5fd0 ee2f5fd0 00000000 ee2c79d4 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] 5fe0: c0049bc4 c000f1b0 00000000 ee2f5ff8 c000f1b0 c0049bd0 00000000 00000000 Message from syslogd@orangepiplus at Nov 23 19:09:47 ... kernel:[ 689.789027] Code: e3530000 1370001c 0a00000c e5942daa (e5903064) but Kernel panic occured.. i don't know this reason... Thanks.
