[Armbian build PR] - Fix cryptroot setup for boards using flash-kernel and ssh unlock on newer dropbear versions
Description
As reported here, the cryptroot functionality was broken on boards that were using flash-kernel. Also because the dropbear config directory and filename is changed in newer dropbear versions, the ssh unlock functionality was broken on bullseye+. This PR fixes the same
Jira reference number AR-1799
How Has This Been Tested?
  • [X] Tested by creating image for RPI4B with cryptroot and ssh unlock enabled. Unlocked cryptroot using ssh key
Checklist:
  • [X] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
