[Armbian build PR] - config: rockchip64_common: fix wrong M0 toolchain prefix
rockchip ATF M0 code should use "arm-none-eabi-" toolchain to compile. "arm-linux-gnueabi-" toolchain causes LD error.
Description
When building rk3399 ATF, following error pops up when linking M0 codes. error: PHDR segment not covered by LOAD segment
How Has This Been Tested?
After this change, rk3399 ATF build passes.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
