RSS Bot Posted August 1, 2023 Share Posted August 1, 2023 rockchip ATF M0 code should use "arm-none-eabi-" toolchain to compile. "arm-linux-gnueabi-" toolchain causes LD error. Description When building rk3399 ATF, following error pops up when linking M0 codes. error: PHDR segment not covered by LOAD segment How Has This Been Tested? After this change, rk3399 ATF build passes. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article Link to comment Share on other sites More sharing options...
