hello, i have a bricked h20 box too.
I can't connect it to my pc to make a recover... (the device don't appear on the device manager)
I try a usb male to male, and push reset button, the resistors to make it maskrom, but the pc never see the box...
I try the cable with a hdmi to usb and work ok...
the serial log is
DDR Version V1.10 20190926
In
330MHz
LPDDR3
Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Die Bus-Width=32 Size=2048MB
mach:14
rd addr 0xC0000000 = 0xFFFF
ERR
Anyone can help me?
Thanx
try to short ROM data lanes that are passed via 51R resistors (8 pcs or 2x 4-resistors assembles hear eMMC). I just shorted any 2 lines between different assembles by tweezer.
Edited by NiTr0
@gpsvitor you clearly need to go in maskrom mode shorting the emmc clock pin to ground.
You installed armbian on emmc without testing first on sdcard, which is something I always suggest to do.
Perhaps your board has 1.5gb of ram like @NiTr0's one?
In such case you will need an image with an updated ddrbin, which is the component failing in your situation.
If you get in maskrom mode, just erase the flash; don't try to reinstall any armbian image because they will all fail and wait for an updated image.
Hello, i already was able to start the maskrom...
At some point i was able to boot the system but nothing on the hdmi...
[    5.743042]   #0: DW-I2S-HDMI
[    5.743048]   #1: SPDIF
[    5.945069] ttyS2 - failed to request DMA, use interrupt mode
[    5.945630] mmcblk2boot1: mmc2:0001 QN16BB partition 2 4.00 MiB
[    5.946326] mmcblk2rpmb: mmc2:0001 QN16BB partition 3 4.00 MiB
[    5.963373]  mmcblk2: p1
[    5.980205] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[    5.987783] squashfs: SQUASHFS error: unable to read xattr id index table
[    6.001110] VFS: Mounted root (squashfs filesystem) readonly on device 179:3.
[    6.014907] devtmpfs: mounted
[    6.019533] Freeing unused kernel memory: 784K
[    6.024032] This architecture does not have kernel memory protection.
[    6.206919] vendor storage:20190527 ret = 0
[    7.638609] random: dropbear: uninitialized urandom read (32 bytes read, 24 bits of entropy available)
Debian GNU/Linux 10 multitool ttyS2
multitool login: root (automatic login)
sh: 1: cannot create /run/motd.dynamic.new: Read-only file system
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
-bash: cannot set terminal process group (-1): Inappropriate ioctl for device
-bash: no job control in this shell
root@multitool:~#)
but now i am stucked to maskrom again after try restore the original firmware...
no serial output @115200...
I lost the complete serial log...
my board have the ddr and emmc together...
here's stable options for dtb overlays: overlays=emmc emmc-pins emmc-hs200 ddr3-528 led-conf7
maybe ddr3 will work even on higher frequency (660 or 800mhz) but in stock it works at 600mhz, so I decided to set it at nearest lower value (I don't need much CPU/GPU power in this box, but factory 330MHz seems to be too low)
At this point the board do not accept any more software... i will put the project to a halt... isn't 100% sutable to my project needs... i'm very thanfull to everybody... thanks
