RSS Bot Posted August 13, 2023 Posted August 13, 2023 Description licheepi-4a: add a .wip for Sipeed LicheePi 4A board The u-boot of LicheePi 4A can be updated without the need to flash the system. Users can manually update it according to the instructions provided by Sipeed's wiki when needed. The opensbi used in LicheePi 4A is not packaged within u-boot using a fit image. Therefore, it is stored in the repository as a binary file. During startup, LicheePi 4A requires loading audio and aon firmware. These two files will also be stored in the repository in binary format. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Successfully built. [x] System startup. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
