njx Posted August 14, 2023 Posted August 14, 2023 I have been trying to get DS3231 to work with the OrangePi Zero 2 via the i2c bus. I have tried setting the following settings in /boot/armbianEnv.txt overlay_prefix=sun8i-h6 overlay=i2c0 i2c1 i2c2 However, I am not able to use i2c tools to read the DS3231. Any suggestions are welcomed. Thank you in advance! 0 Quote
serg_stetsuk Posted January 7, 2024 Posted January 7, 2024 (edited) Hi. It's probably a bit late. On OrangePi Zero2 thereis i2c3 interface. Thus you must create your own DT overlay for i2c3 interface. See https://github.com/armbian/sunxi-DT-overlays/blob/master/sun50i-h6/sun50i-h6-i2c2.dts as an example. Let's say you create file sun50i-h6-i2c3.dts: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; fragment@0 { target-path = "/aliases"; __overlay__ { i2c3 = "/soc/i2c@5002c00"; }; }; fragment@1 { target = <&i2c3>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&i2c3_ph_pins>; status = "okay"; }; }; }; Compile this file into a binary device-tree overlay blob: dtc -I dts -O dtb -o sun50i-h6-i2c3.dtbo sun50i-h6-i2c3.dts Set permmissions and copy compiled file into /boot/dtb/allwinner/overlay: chmod +x ./sun50i-h6-i2c3.dtbo sudo cp ./sun50i-h6-i2c3.dtbo /boot/dtb/allwinner/overlay Then use the following in your armbianEnv.txt: overlay_prefix=sun50i-h6 overlay=i2c3 Edited January 7, 2024 by serg_stetsuk improved answer 0 Quote
