Unable to get i2c connection to work on Orange Pi Zero 2
njx
I have been trying to get DS3231 to work with the OrangePi Zero 2 via the i2c bus.
I have tried setting the following settings in /boot/armbianEnv.txt
overlay_prefix=sun8i-h6
overlay=i2c0 i2c1 i2c2
However, I am not able to use i2c tools to read the DS3231.
Any suggestions are welcomed. Thank you in advance!
Hi. It's probably a bit late. On OrangePi Zero2 thereis i2c3 interface. Thus you must create your own DT overlay for i2c3 interface. See https://github.com/armbian/sunxi-DT-overlays/blob/master/sun50i-h6/sun50i-h6-i2c2.dts as an example. Let's say you create file sun50i-h6-i2c3.dts:
/dts-v1/;
/plugin/;
	compatible = "allwinner,sun50i-h6";
	fragment@0 {
		target-path = "/aliases";
		__overlay__ {
			i2c3 = "/soc/i2c@5002c00";
	fragment@1 {
		target = <&i2c3>;
		__overlay__ {
			pinctrl-names = "default";
			pinctrl-0 = <&i2c3_ph_pins>;
			status = "okay";
Compile this file into a binary device-tree overlay blob:
dtc -I dts -O dtb -o sun50i-h6-i2c3.dtbo sun50i-h6-i2c3.dts
Set permmissions and copy compiled file into /boot/dtb/allwinner/overlay:
chmod +x ./sun50i-h6-i2c3.dtbo
sudo cp ./sun50i-h6-i2c3.dtbo /boot/dtb/allwinner/overlay
Then use the following in your armbianEnv.txt:
overlay_prefix=sun50i-h6
overlay=i2c3
Edited by serg_stetsuk
improved answer
