thanks for supporting this device :)
I'm trying to install pivccu (homematic smarthome) on armbian to use it with homeassistant.
It's not officially supported (yet) but I got it running with the default hardkernel ubuntu image.
https://github.com/alexreinert/piVCCU/blob/master/docs/setup/armbian.md
I can't seem to find the kernel headers/sources for my kernel. Any Ideas?
Below is what I found. I'm willing to go back to 6.1.12 if that doesn't cause any issues.
Can't do it via armbian-config. Do I need to download an image from the archive and reinstall?
uname -a
Linux odroid 6.3.4-rk3568-odroid #5 SMP PREEMPT Wed May 24 16:30:25 UTC 2023 aarch64 GNU/Linux
apt search $(uname -r)
Sorting... Done
Full Text Search... Done
linux-dtb-edge-rk3568-odroid/now 23.05.1--6.3.4-S17f2-Db165-P80b4-C323dHfe66-HK01ba-Vc222-B9c18 arm64 [installed,local]
  Armbian Linux edge DTBs version "6.3.4" git revision "17f2d782f18c9a49943ea723d7628da1837c9204" codename "Hurr durr Ima ninja sloth" drivers hash "b165677e9cfc7376" patches hash "80b43c0ea45182e1" .config hash "323dfc8836b51fe8" .config hook hash "fe661159ee64825e" variables hash "" framework bash hash "9c188aa4807ed506" in /boot/dtb-6.3.4-rk3568-odroid
linux-image-edge-rk3568-odroid/now 23.05.1--6.3.4-S17f2-Db165-P80b4-C323dHfe66-HK01ba-Vc222-B9c18 arm64 [installed,local]
  Armbian Linux edge kernel image version "6.3.4" git revision "17f2d782f18c9a49943ea723d7628da1837c9204" codename "Hurr durr Ima ninja sloth" drivers hash "b165677e9cfc7376" patches hash "80b43c0ea45182e1" .config hash "323dfc8836b51fe8" .config hook hash "fe661159ee64825e" variables hash "" framework bash hash "9c188aa4807ed506"
apt search rk3568
Sorting... Done
linux-headers-edge-rk3568-odroid/bookworm,now 23.02.2 arm64 [installed]
  Linux kernel headers for 6.1.12-rk3568-odroid on arm64 edge
linux-source-6.1.12-edge-rk3568-odroid/bookworm,bookworm 6.1.12-edge-rk3568-odroid+23.02.2 all
  This package provides the source code for the Linux kernel 6.1.12
ls -lah /usr/src/
total 28K
drwxr-xr-x  7 root root 4,0K Aug 14 09:35 .
drwxr-xr-x 11 root root 4,0K Mai 17 00:41 ..
drwxr-xr-x  4 root root 4,0K Aug 12 13:11 linux-headers-6.1.0-11-arm64
drwxr-xr-x  4 root root 4,0K Aug 12 13:10 linux-headers-6.1.0-11-common
drwxr-xr-x 25 root root 4,0K Aug 14 08:04 linux-headers-6.1.12-rk3568-odroid
lrwxrwxrwx  1 root root   23 Aug  8 13:18 linux-kbuild-6.1 -> ../lib/linux-kbuild-6.1
drwxrwxr-x 27 root root 4,0K Feb 18 00:33 linux-source-6.1.12-rk3568-odroid
drwxr-xr-x  2 root root 4,0K Aug 12 13:11 pivccu-1.0.82
