[Armbian build PR] - Update armbian-add-overlay
Description
Prior to this patch, adding a user-overlay using the script will add the filename with a space after the user-overlays=, even if there aren't any overlays present. This will result in the following: before adding: user_overlays= after adding: user_overlays= rk3588-i2c0-m1.dts
with a space. This patch will add another else branch to handle this, as well as handling any additional spaces present prior.
New script does this
before adding: user_overlays= or user_overlays= after adding: user_overlays=rk3588-i2c0-m1.dts
Adding more overlays works as intended, with a space and the name.dtbo
How Has This Been Tested?
  • [x] Copied conditional branch part of the code, modified changes and ran all the possible situations, worked as intended.
  • [x] Modified the script the same way on my Rock5B with Armbian Bookworm 23.5.1 install and tried adding multiple overlays, worked as intended.
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
    • Not strictly required
  • [x] I have made corresponding changes to the documentation
    • Not required
  • [x] Any dependent changes have been merged and published in downstream modules
    • Not required
View the full article
