Creating the name of an networkcard (known as NIC)
Go to solution Solved by yxcv,
As it just happened, na OK, a few hours earlier, rhe name of an networkcard was changed.
Why?
How?
By doing nothing special a real time consumpting work i had to get out what to change now, changing all the scripts and hoping nothing ist lost.
what did build all the link local addresses?
  • Solution
Es reicht,
eigene Lösung
wenn man den Senf dazu
auch noch breittritt bis Kuhfladengröße?
Wenn jede Menge Adabeis jede Menge Unsinn beisteuern?
Dann reichts.
