RSS Bot Posted August 16, 2023 Posted August 16, 2023 odroidm1: de-infest Petitboot ๐ฅ use Kwiboo's 2023.10-rc2+gmac u-boot odroidm1/edge (rk3568-odroid): bump to 6.4.y, update config, rebase patches to 6.4.10 odroidm1/edge (rk3568-odroid): bump to 6.5-rc6; manually fix RK808 breakage in .config; rebase patches add patch to remove Petitboot-mandated MTD partitions this way we have access to the full flash, and can write our own u-boot to it rebase all patches odroidm1/edge (rk3568-odroid): drop 6.3 and 6.4 patches odroidm1: de-infest Petitboot ๐ฅ use Kwiboo's 2023.10-rc2+gmac u-boot using Kwiboo's rk3568-2023.10-gmac branch with BINMAN-handled blobs patches: boot usb first preboot pci/usb enum/scan usage instructions: build & burn image to SD card insert SD card into board hold the recovery (RCY) button and power on the board watch board boot de-infest Petitboot: use armbian-install to install bootloader to MTD if you don't, you'll need to hold the recovery button every boot optionally: use armbian-install to install OS to eMMC/NVMe/USB power-off board remove SD card (new u-boot always boots SD first!) boot into your newly de-infested machine boot order: USB, SD, MMC, NVME, SCSI (SATA) de-infested machine can now boot (directly) from USB/SATA/NVMe: Armbian UEFI-arm64 Fedora 38 aarch64 Talos arm64 others... extra: new u-boot by Kwiboo (with GMAC patches) gives us stable MAC address although it is based on cpuid#, doesn't match the HK sticker on the board odroidm1: update DDR/BL31 blobs; cleanup old Petitboot stuff this depends on https://github.com/armbian/rkbin/pull/20 View the full article
