ct100 Posted August 21, 2023 Share Posted August 21, 2023 (edited) I have Armbian running on a NanoPi R6C 8GB with 32GB eMMC. I made a new Armbian image with the build framework that uses newest linux-u-boot-nanopi-r6s-legacy 23.8.0-trunk linux-dtb-legacy-rk35xx 23.8.0-trunk linux-image-legacy-rk35xx 23.8.0-trunk Booted from microSD this system has an idle power consumption of 0,92w. I can access both the eMMC and microSD storage. When i transfer this system from microSD to eMMC with "nand-sata-install" to boot & OS on eMMC and cold boot without the microSD, the idle power consumption increases to 1,21w. After a shutdown and booting from the microSD again the idle power consumption is back at 0,92w. So far i have not been able to find a reason for this. The only things i noticed was: (microSD) Device Start End Sectors Size Type /dev/mmcblk1p1 32768 557055 524288 256M Linux extended boot /dev/mmcblk1p2 557056 61702144 61145089 29.2G Linux filesystem (eMMC) Device Start End Sectors Size Type /dev/mmcblk0p1 32768 59998207 59965440 28.6G Linux filesystem While microSD uses a vfat partition for /boot and an EXT4 partition for the OS the eMMC has a single EXT4 partition for everything. Does that change how the system is booting? https://github.com/radxa/u-boot/commit/bf47e8171f44804c7f2004f53d3f05801f8dbbb8 Different drive strength settings in u-boot for when eMMC is boot drive or not? Can that really increase the power usage of the eMMC by 0,3w? Edited August 21, 2023 by ct100 0 Quote Link to comment Share on other sites More sharing options...
Dantes Posted August 21, 2023 Share Posted August 21, 2023 There is a thread on OpenWRT, where it show it can be installed on sdcard or emmc. You could try installing those and measuring the power usage between sdcard and emmc. If the problem is the same, I'll bet its somehow related to the emmc driver. link: https://forum.openwrt.org/t/nanopi-r6s-linux-6-3-arm-soc-updates/153072/34 link to images for nanopi: https://github.com/mj22226/openwrt/releases/tag/linux-6.4 0 Quote Link to comment Share on other sites More sharing options...
ct100 Posted August 28, 2023 Author Share Posted August 28, 2023 (edited) I found the reason this happens. Its not the eMMC itself, the boot from eMMC or booting from FAT vs EXT4. It's the much faster system boot speed from eMMC and the network configuration that leads to this bug. The device that consumes the additional idle power is the Realtek RTL8125 2.5GbE NIC when left in an bugged unmanaged/unconfigured/off state. When using stock Armbian with Network-Manager it seems to depend on the image, software distribution and the system boot speed with how often the Realtek NIC gets into this bugged state. Properly configuring the NIC in Network-Manager prevents this from happening. When using Armbian Bullseye with OpenMediaVault installed with the OMVExtras InstallScript this can be reproduced 100%. The InstallScript (without using the option -n to skip network configuration) removes Network-Manager and lets systemd-networkd and OpenMediaVault/Netplan manage the network. Since the MAC of the Realtek RTL8125 2.5GbE NIC is not fixed and changes every boot systemd-networkd with the policy "MACAddressPolicy=persistent" (default in /usr/lib/systemd/network/99-default.link) automatically adds a persistent MAC address to the Adapter. At the same time OpenMediaVault creates netplan files that assign network configuration based on this added MAC address. This leads to a race condition in systemd-networkd. If systemd-networkd adds the persistent MAC to the adapter before it tries to assign the configuration matched to this persistent MAC everything works as expected. When the system boots faster systemd-networkd tries to match the configuration to a MAC that is not added yet to the adapter and that leaves the adapter off, unmanaged and bugged. (In these code parts eth0 = GMAC & Realtek RTL8211F 1GbE and Realtek RTL8125 2.5GbE NIC = enP3p49s0) Random MAC adresses: Aug 28 09:53:57 nanopi-r6s kernel: r8125 0003:31:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00 Aug 28 09:53:57 nanopi-r6s kernel: r8125 0003:31:00.0 (unnamed net_device) (uninitialized): Random ether addr 4e:54:94:b5:ad:c7 OMV Netplan file (matching with mac!): root@nanopi-r6s:~# cat /etc/netplan/20-openmediavault-enP3p49s0.yaml network: ethernets: enP3p49s0: match: macaddress: de:d1:aa:55:c9:bf accept-ra: true dhcp4: yes dhcp4-overrides: use-dns: true use-domains: true dhcp6: yes dhcp6-overrides: use-dns: true use-domains: true Netplan auto generated systemd-networkd .network: root@nanopi-r6s:~# cat /run/systemd/network/10-netplan-enP3p49s0.network [Match] MACAddress=de:d1:aa:55:c9:bf [Network] DHCP=yes LinkLocalAddressing=ipv6 IPv6AcceptRA=yes [DHCP] RouteMetric=100 UseMTU=true UseDomains=true When booting from slow microSD status of enP3p49s0 is ok: root@nanopi-r6s:~# networkctl IDX LINK TYPE OPERATIONAL SETUP 1 lo loopback carrier unmanaged 2 eth0 ether routable configured 3 enP3p49s0 ether no-carrier configuring 3 links listed. root@nanopi-r6s:~# networkctl status enP3p49s0 ● 3: enP3p49s0 Link File: /usr/lib/systemd/network/99-default.link Network File: /run/systemd/network/10-netplan-enP3p49s0.network Type: ether State: no-carrier (configuring) Path: platform-fe180000.pcie-pci-0003:31:00.0 Driver: r8125 Vendor: Realtek Semiconductor Co., Ltd. Model: RTL8125 2.5GbE Controller HW Address: de:d1:aa:55:c9:bf HW Permanent Address: 4e:54:94:b5:ad:c7 MTU: 1500 (min: 68, max: 9194) QDisc: mq IPv6 Address Generation Mode: eui64 Queue Length (Tx/Rx): 4/4 Auto negotiation: yes Speed: n/a Port: tp DHCP6 Client DUID: DUID-EN/Vendor:0000ab1166a0671791d79f890000 When booting from much faster eMMC enP3p49s0 is left in a bugged state: root@nanopi-r6s:~# networkctl IDX LINK TYPE OPERATIONAL SETUP 1 lo loopback carrier unmanaged 2 eth0 ether routable configured 3 enP3p49s0 ether off unmanaged 3 links listed. root@nanopi-r6s:~# networkctl status enP3p49s0 ● 3: enP3p49s0 Link File: /usr/lib/systemd/network/99-default.link Network File: n/a Type: ether State: off (unmanaged) Path: platform-fe180000.pcie-pci-0003:31:00.0 Driver: r8125 Vendor: Realtek Semiconductor Co., Ltd. Model: RTL8125 2.5GbE Controller HW Address: de:d1:aa:55:c9:bf HW Permanent Address: 92:f6:18:f3:59:af MTU: 1500 (min: 68, max: 9194) QDisc: noop IPv6 Address Generation Mode: eui64 Queue Length (Tx/Rx): 4/4 Auto negotiation: yes Speed: n/a Port: tp The fix is to install OpenMediaVault without re configuring the network with InstallScript option -n. That keeps Network-Manger and doesn't add the ethernet adapters to the OMV database. Another option is to remove Network-Manager and also remove the matching by MAC address from OMV netplan files by editing "/srv/salt/omv/deploy/systemd-networkd/netplan/files/ethernet.j2" and deleting: match: macaddress: {{ mac_address }} After saving and applying the new network configuration in OMV webgui the MAC address matching is gone and adapters get only matched by name. Edited August 28, 2023 by ct100 1 Quote Link to comment Share on other sites More sharing options...
ct100 Posted September 3, 2023 Author Share Posted September 3, 2023 Update: I reported this bug to OpenMediaVault and it was fixed in OpenMediaVault Version 6.8.0. https://github.com/openmediavault/openmediavault/commit/82c74b07fb7f57a6c55832f6e3aa17ba6b67b55d (Issue #1589: Fix a problem in the netplan.io configuration for ethernet network interfaces with non-permanent MAC addresses.) For stock Armbian with Network-Manager you still have to make sure that the Realtek RTL8125 2.5GbE NIC is correctly configured. 0 Quote Link to comment Share on other sites More sharing options...
q-bert Posted May 3 Share Posted May 3 @ct100 How can I make sure my NIC is configured correctly? cat /etc/armbian-image-release # PLEASE DO NOT EDIT THIS FILE BOARD=rock-5b BOARD_NAME="Rock 5B" BOARDFAMILY=rockchip-rk3588 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=1e6fdcb13 LINUXFAMILY=rk35xx ARCH=arm64 IMAGE_TYPE=stable BOARD_TYPE=csc INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= VENDOR="Armbian" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://www.armbian.com/" VENDORSUPPORT="https://forum.armbian.com" VENDORBUGS="https://www.armbian.com/bugs" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=23.2.1 REVISION=23.2.1 IMAGE_UUID=7c90ea8a-9f70-45ed-af73-86d1927c2fbc uname -a Linux rock5b 5.10.160-legacy-rk35xx 0 Quote Link to comment Share on other sites More sharing options...
ct100 Posted May 3 Author Share Posted May 3 @q-bert Use the command "nmcli dev status" (for Network-Manager) or "networkctl" (for systemd-networkd) and make sure the NIC is not off / unmanaged. 0 Quote Link to comment Share on other sites More sharing options...
q-bert Posted May 3 Share Posted May 3 (edited) @ct100 Thank you! "nmcli dev status" did the job (I wasn't aware of it). I tried ""networkctl" before and all interfaces were unmanaged. Looks good now: nmcli dev status DEVICE TYPE STATE CONNECTION enP4p65s0 ethernet connected Armbian ethernet docker0 bridge connected (externally) docker0 Edited May 3 by q-bert 0 Quote Link to comment Share on other sites More sharing options...
