Let me introduce my device:
- tanix tx68
- wifi/bluetooth not working - tried building modules for aw869a, failed to load, tried pre-built ones in form of .deb packages, didn't work either
- internal storage not working - failed mounting it from within armbian
- 1x USB2 port not working (works on default Android, doesn't work on slimboxTV Android)
- IR not working
- using an image from https://github.com/NickAlilovic/build/releases as is, great!
- using it for Home Assistant
- using external WiFi adapter
- headless, tried at first with an external display but it kept stalling/crashing the GPU every few seconds and kept getting lower resolution.
To be honest, an Intel N100 for 4x the price would have been a better choice, though tx68 is usable.
aw869a chip uses the aic8800 firmware. The drivers are old but have been ported to newer kernel. You can find patches here.
https://github.com/LYU4662/t95zplus-h618-build/tree/master/userpatches/kernel/archive/sunxi-6.7
For internal storage not working, You need to extract your dts and find the correct gpio settings.
USB2 probably needs to be enable in the DTS.
IR not working. There are posts a few pages back that enables IR.
Thanks, although the aic8800_fdrv module fails modprobe due to no device found error, Bluetooth module loads, but it was same when I compiled the module myself a month ago. It is fine for what it is though, maybe it will work without accessories in the future
regarding  openvfd.dts file
Tanix Tx6s PCB is mounted upside down in the case and thats why the openvfd.dts file is different.
swapping my SD card between Vontar (transpeed) and Tanix resulted in the time being displayed upside down lol.
  Quote
openvfd.dts  for Tanix
/dts-v1/;
/plugin/;
   fragment@0 {
      target-path = "/";
      __overlay__ {
         openvfd {
        compatible = "open,vfd";
        dev_name = "openvfd";
        openvfd_gpio_clk = <&pio 8 11 6>;
        openvfd_gpio_dat = <&pio 8 12 6>;
        vfd_gpio_chip_name = "0300b000.pinctrl";
        openvfd_chars = [02 04 03 02 01];
        openvfd_dot_bits = [00 01 03 02 04 05 06];
        openvfd_display_type = <0x03000001>;
        status = "okay";
openvfd.dts  for Vontar (Transpeed)
/dts-v1/;
/plugin/;
   fragment@0 {
      target-path = "/";
      __overlay__ {
         openvfd {
        openvfd_gpio_clk = <&pio 8 11 0>;
        openvfd_gpio_dat = <&pio 8 12 0>;
        openvfd_chars = [02 01 02 03 04];
        openvfd_display_type = <0x03000000>;
        status = "okay";
Expand
Posted (edited)
  Quote
Expand
@UnhealthyTweak that's the thing about these TVBoxs.. It's community supported. Unless someone has the same box as yours and releases the image.  You might be waiting forever. I have a transpeed 8K618-T and even this box has more than one wifi/bluetooth chip. Usually it's a broadcom wifi chip and only needs firmware changes. Some boxes need a patch to include the firmware like broadcom 43342. Your box has a different wifi chip.
Try this image.. if it doesn't work it might be the GPIO # that's different. You would need to extract your gpio #  from the orignal android DTS.
Edited by Nick A
Posted (edited)
is it safe to do ?
sudo apt update
sudo apt upgrade
I have been unable to boot after doing this, had to burn fresh .img to sdcard to boot again. I have done this previously with no issues (is this due to ubuntu noble 24.11.0 >  24.11.2 updating ?)
here is update and upgrade list and update. No Boot after reboot. :(
  Quote
firepower@transpeed-8k618-t:~$ sudo apt update
[sudo] password for firepower:
Get:2 https://packages.microsoft.com/repos/code stable InRelease [3,590 B]
Get:1 https://cli.github.com/packages stable InRelease [3,917 B]
Hit:4 http://ports.ubuntu.com noble InRelease
Get:5 https://packages.microsoft.com/repos/code stable/main arm64 Packages [18.0 kB]
Get:6 https://packages.microsoft.com/repos/code stable/main amd64 Packages [17.9 kB]
Get:7 https://packages.microsoft.com/repos/code stable/main armhf Packages [18.1 kB]
Get:8 http://ports.ubuntu.com noble-security InRelease [126 kB]
Get:9 https://cli.github.com/packages stable/main arm64 Packages [345 B]
Get:3 http://netcup.armbian.com/apt noble InRelease [52.4 kB]
Get:10 http://ports.ubuntu.com noble-updates InRelease [126 kB]
Get:11 http://ports.ubuntu.com noble-backports InRelease [126 kB]
Get:12 http://ports.ubuntu.com noble-security/main arm64 Packages [616 kB]
Get:13 http://netcup.armbian.com/apt noble/main arm64 Packages [1,159 kB]
Get:14 http://ports.ubuntu.com noble-security arm64 Contents (deb) [40.0 MB]
Get:15 http://netcup.armbian.com/apt noble/main all Packages [15.6 kB]
Get:16 http://netcup.armbian.com/apt noble/main all Contents (deb) [38.6 kB]
Get:17 http://netcup.armbian.com/apt noble/main arm64 Contents (deb) [19.1 MB]
Get:18 http://ports.ubuntu.com noble-security/universe arm64 Packages [707 kB]
Get:19 http://ports.ubuntu.com noble-updates/main arm64 Packages [845 kB]
Get:20 http://ports.ubuntu.com noble-updates arm64 Contents (deb) [41.6 MB]
Get:21 http://ports.ubuntu.com noble-updates/restricted arm64 Packages [667 kB]
Get:22 http://ports.ubuntu.com noble-updates/universe arm64 Packages [915 kB]
Get:23 http://ports.ubuntu.com noble-updates/multiverse arm64 Packages [15.1 kB]
Get:24 http://netcup.armbian.com/apt noble/noble-utils arm64 Packages [19.5 kB]
Get:25 http://netcup.armbian.com/apt noble/noble-utils arm64 Contents (deb) [30.8 kB]
Get:26 http://netcup.armbian.com/apt noble/noble-desktop arm64 Packages [529 kB]
Get:27 http://netcup.armbian.com/apt noble/noble-desktop all Packages [43.5 kB]
Get:28 http://netcup.armbian.com/apt noble/noble-desktop arm64 Contents (deb) [38.1 kB]
Fetched 107 MB in 39s (2,752 kB/s)
Reading package lists... Done
Building dependency tree... Done
10 packages can be upgraded. Run 'apt list --upgradable' to see them.
firepower@transpeed-8k618-t:~$ apt list --upgradable
Listing... Done
armbian-config/noble,noble 24.11.2 all [upgradable from: 24.11.0-trunk]
armbian-firmware/noble,noble 24.11.2 all [upgradable from: 24.11.0-trunk]
armbian-noble-desktop-cinnamon/noble,noble 24.11.1 all [upgradable from: 24.11.0-trunk]
armbian-plymouth-theme/noble,noble 24.11.2 all [upgradable from: 24.11.0-trunk]
armbian-zsh/noble,noble 24.11.2 all [upgradable from: 24.11.0-trunk]
base-files/noble 24.11.2-13ubuntu10-noble arm64 [upgradable from: 24.11.0-trunk-13ubuntu10-noble]
fake-ubuntu-advantage-tools/noble,noble 24.11.2 all [upgradable from: 24.11.0-trunk]
gh/noble,unknown 2.63.1 arm64 [upgradable from: 2.63.0]
linux-dtb-edge-sunxi64/noble 24.11.1 arm64 [upgradable from: 24.11.0-trunk]
linux-image-edge-sunxi64/noble 24.11.1 arm64 [upgradable from: 24.11.0-trunk]
firepower@transpeed-8k618-t:~$ sudo apt upgrade
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  geocode-glib-common gir1.2-adw-1 gir1.2-atspi-2.0 gir1.2-gck-2 gir1.2-gcr-4 gir1.2-gdesktopenums-3.0 gir1.2-gdm-1.0 gir1.2-geoclue-2.0 gir1.2-gnomebg-4.0 gir1.2-gnomebluetooth-3.0 gir1.2-gnomedesktop-4.0
  gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 gir1.2-gtk-4.0 gir1.2-gweather-4.0 gir1.2-ibus-1.0 gir1.2-javascriptcoregtk-4.1 gir1.2-javascriptcoregtk-6.0 gir1.2-mutter-14 gir1.2-nma4-1.0
  gir1.2-rsvg-2.0 gir1.2-snapd-2 gnome-bluetooth-3-common gnome-settings-daemon gnome-settings-daemon-common gnome-shell-common gstreamer1.0-pipewire libdjvulibre-text libdjvulibre21 libeis1
  libevdocument3-4t64 libgcc-14-dev libgccjit0 libgdm1 libgeoclue-2-0 libgeocode-glib-2-0 libgif7 libgjs0g libgnome-autoar-0-0 libgnome-bg-4-2t64 libgnome-bluetooth-3.0-13 libgnome-desktop-4-2t64
  libgweather-4-0t64 libgweather-4-common libgxps2t64 libharfbuzz-icu0 libhyphen0 libibus-1.0-5 libjavascriptcoregtk-4.1-0 libjavascriptcoregtk-6.0-1 libkpathsea6 libm17n-0 libmanette-0.2-0 libmousepad0
  libmozjs-115-0t64 libmutter-14-0 libnma-gtk4-0 libotf1 libspectre1 libsynctex2 libtree-sitter0 libwebpdecoder3 libwoff1 m17n-db mutter-common mutter-common-bin python3-debconf ubuntu-wallpapers
  ubuntu-wallpapers-noble update-notifier-common xdg-dbus-proxy
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
  whiptail
The following packages will be upgraded:
  armbian-config armbian-firmware armbian-noble-desktop-cinnamon armbian-plymouth-theme armbian-zsh base-files fake-ubuntu-advantage-tools gh linux-dtb-edge-sunxi64 linux-image-edge-sunxi64
10 to upgrade, 1 to newly install, 0 to remove and 0 not to upgrade.
Need to get 165 MB of archives.
After this operation, 3,389 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://netcup.armbian.com/apt noble/noble-utils arm64 base-files arm64 24.11.2-13ubuntu10-noble [68.8 kB]
Get:11 http://ports.ubuntu.com noble/main arm64 whiptail arm64 0.52.24-2ubuntu2 [17.5 kB]
Get:2 http://armbian.tnahosting.net/apt noble/main arm64 armbian-config all 24.11.2 [127 kB]
Get:5 http://netcup.armbian.com/apt noble/main arm64 armbian-plymouth-theme all 24.11.2 [108 kB]
Get:9 http://netcup.armbian.com/apt noble/main arm64 linux-dtb-edge-sunxi64 arm64 24.11.1 [129 kB]
Get:6 http://fi.mirror.armbian.de/apt noble/main arm64 armbian-zsh all 24.11.2 [12.0 MB]
Get:3 http://armbian.tnahosting.net/apt noble/main arm64 armbian-firmware all 24.11.2 [91.7 MB]
Get:4 http://armbian.tnahosting.net/apt noble/noble-desktop arm64 armbian-noble-desktop-cinnamon all 24.11.1 [16.6 MB]
Get:7 http://armbian.tnahosting.net/apt noble/main arm64 fake-ubuntu-advantage-tools all 24.11.2 [1,356 B]
Get:8 http://armbian.tnahosting.net/apt noble/noble-utils arm64 gh arm64 2.63.1 [12.7 MB]
Ign:6 http://fi.mirror.armbian.de/apt noble/main arm64 armbian-zsh all 24.11.2
Get:10 http://fi.mirror.armbian.de/apt noble/main arm64 linux-image-edge-sunxi64 arm64 24.11.1 [31.9 MB]
Fetched 161 MB in 20min 30s (131 kB/s)
(Reading database ... 151488 files and directories currently installed.)
Preparing to unpack .../base-files_24.11.2-13ubuntu10-noble_arm64.deb ...
Unpacking base-files (24.11.2-13ubuntu10-noble) over (24.11.0-trunk-13ubuntu10-noble) ...
Setting up base-files (24.11.2-13ubuntu10-noble) ...
motd-news.timer is a disabled or a static unit not running, not starting it.
motd-news.service is a disabled or a static unit not running, not starting it.
Selecting previously unselected package whiptail.
(Reading database ... 151487 files and directories currently installed.)
Preparing to unpack .../0-whiptail_0.52.24-2ubuntu2_arm64.deb ...
Unpacking whiptail (0.52.24-2ubuntu2) ...
Preparing to unpack .../1-armbian-config_24.11.2_all.deb ...
Unpacking armbian-config (24.11.2) over (24.11.0-trunk) ...
dpkg: warning: unable to delete old directory '/usr/lib/armbian-config': Directory not empty
Preparing to unpack .../2-armbian-firmware_24.11.2_all.deb ...
Unpacking armbian-firmware (24.11.2) over (24.11.0-trunk) ...
Preparing to unpack .../3-armbian-noble-desktop-cinnamon_24.11.1_all.deb ...
Unpacking armbian-noble-desktop-cinnamon (24.11.1) over (24.11.0-trunk) ...
Preparing to unpack .../4-armbian-plymouth-theme_24.11.2_all.deb ...
Unpacking armbian-plymouth-theme (24.11.2) over (24.11.0-trunk) ...
Preparing to unpack .../5-armbian-zsh_24.11.2_all.deb ...
Unpacking armbian-zsh (24.11.2) over (24.11.0-trunk) ...
Preparing to unpack .../6-fake-ubuntu-advantage-tools_24.11.2_all.deb ...
Unpacking fake-ubuntu-advantage-tools (24.11.2) over (24.11.0-trunk) ...
Preparing to unpack .../7-gh_2.63.1_arm64.deb ...
Unpacking gh (2.63.1) over (2.63.0) ...
Preparing to unpack .../8-linux-dtb-edge-sunxi64_24.11.1_arm64.deb ...
Armbian 'linux-dtb-edge-sunxi64' for '6.11.9-edge-sunxi64': 'preinst' starting.
Armbian 'linux-dtb-edge-sunxi64' for '6.11.9-edge-sunxi64': 'preinst' finishing.
Unpacking linux-dtb-edge-sunxi64 (24.11.1) over (24.11.0-trunk) ...
Preparing to unpack .../9-linux-image-edge-sunxi64_24.11.1_arm64.deb ...
Armbian 'linux-image-edge-sunxi64' for '6.10.10-edge-sunxi64': 'prerm' starting.
Armbian 'linux-image-edge-sunxi64' for '6.10.10-edge-sunxi64': 'prerm' finishing.
Armbian 'linux-image-edge-sunxi64' for '6.11.9-edge-sunxi64': 'preinst' starting.
Armbian 'linux-image-edge-sunxi64' for '6.11.9-edge-sunxi64': 'preinst' finishing.
Unpacking linux-image-edge-sunxi64 (24.11.1) over (24.11.0-trunk) ...
Armbian 'linux-image-edge-sunxi64' for '6.10.10-edge-sunxi64': 'postrm' starting.
Armbian 'linux-image-edge-sunxi64' for '6.10.10-edge-sunxi64': 'postrm' finishing.
Setting up fake-ubuntu-advantage-tools (24.11.2) ...
Setting up linux-image-edge-sunxi64 (24.11.1) ...
Armbian 'linux-image-edge-sunxi64' for '6.11.9-edge-sunxi64': 'postinst' starting.
 * dkms: autoinstall for kernel 6.11.9-edge-sunxi64 was skipped since the kernel headers for this kernel do not seem to be installed
update-initramfs: Generating /boot/initrd.img-6.11.9-edge-sunxi64
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.11.9-edge-sunxi64
Image Name:   uInitrd
Created:      Thu Dec  5 17:35:13 2024
Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
Data Size:    18088214 Bytes = 17664.27 KiB = 17.25 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.11.9-edge-sunxi64 to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.11.9-edge-sunxi64'
update-initramfs: Armbian: done.
Remove unused generated file: /boot/uInitrd-6.10.10-edge-sunxi64
Remove unused generated file: /boot/initrd.img-6.10.10-edge-sunxi64
Armbian: update last-installed kernel symlink to 'Image'...
'/boot/Image' -> 'vmlinuz-6.11.9-edge-sunxi64'
Armbian: Debian compat: linux-update-symlinks install 6.11.9-edge-sunxi64 boot/vmlinuz-6.11.9-edge-sunxi64
I: /boot/vmlinuz.old is now a symlink to vmlinuz-6.11.9-edge-sunxi64
I: /boot/initrd.img.old is now a symlink to initrd.img-6.11.9-edge-sunxi64
I: /boot/vmlinuz is now a symlink to vmlinuz-6.11.9-edge-sunxi64
I: /boot/initrd.img is now a symlink to initrd.img-6.11.9-edge-sunxi64
Armbian 'linux-image-edge-sunxi64' for '6.11.9-edge-sunxi64': 'postinst' finishing.
Setting up armbian-zsh (24.11.2) ...
Setting up armbian-noble-desktop-cinnamon (24.11.1) ...
Armbian 'armbian-noble-desktop-cinnamon' for '1-V1220-Bed17-R448a': 'postinst' starting.
removed '/etc/dconf/db/local.d/00-desktop'
'/dev/null' -> '/etc/dconf/db/local.d/00-desktop'
removed '/etc/dconf/profile/user'
'/dev/null' -> '/etc/dconf/profile/user'
Armbian 'armbian-noble-desktop-cinnamon' for '1-V1220-Bed17-R448a': 'postinst' finishing.
Setting up gh (2.63.1) ...
Setting up armbian-firmware (24.11.2) ...
Setting up whiptail (0.52.24-2ubuntu2) ...
Setting up linux-dtb-edge-sunxi64 (24.11.1) ...
Armbian 'linux-dtb-edge-sunxi64' for '6.11.9-edge-sunxi64': 'postinst' starting.
Armbian: DTB: symlinking /boot/dtb to /boot/dtb-6.11.9-edge-sunxi64...
'dtb' -> 'dtb-6.11.9-edge-sunxi64'
Armbian 'linux-dtb-edge-sunxi64' for '6.11.9-edge-sunxi64': 'postinst' finishing.
Setting up armbian-plymouth-theme (24.11.2) ...
update-initramfs: deferring update (trigger activated)
Setting up armbian-config (24.11.2) ...
Processing triggers for install-info (7.1-3build2) ...
Processing triggers for man-db (2.12.0-4build2) ...
Processing triggers for cracklib-runtime (2.9.6-5.1build2) ...
Processing triggers for initramfs-tools (0.142ubuntu25.4) ...
Image Name:   uInitrd
Created:      Thu Dec  5 17:36:01 2024
Data Size:    18088293 Bytes = 17664.35 KiB = 17.25 MiB
Expand
Edited by firepower
Posted (edited)
  Quote
Expand
Remember you have a custom kernel. You need to block kernel updates with the armbian config tool.
Edited by Nick A
I Have one transpeed 8k16-t (4GB Ram, 32GB EMMC) just like @Nick A, could I just compile the kernel and flash it and update the android kernel? I'm using as tvbox and i see it has about 2,5 GB ram free. I would like to use it on termux with docker, but i need to enable some features and recompile the kernel. Can anyone give me a hint? Thanks.
Reinaldo if you want to modify the android kernel visit the XDA forums. Android uses an old linux kernel with Board Support Package (BSP) provided by Allwinner.
Armbian build uses the mainline linux kernel with patches. No support from Allwinner.  Just a few hackers that reversed engineered and back port sources from the BSP kernel.
Posted (edited)
I been comparing the different bluetooth patches for transpeed, vontar and tanix TV  boxes. I made an overlay bluetooth.dts with the changes i need for my vontar tv box using transpped image. using overlay allows you make changes for testing. got the idea from the openvfd.dts overlay by @MMorales
cp bluetooth.dts  /boot/dtb/allwinner/overlay/
sudo armbian-add-overlay /boot/dtb/allwinner/overlay/bluetooth.dts
  Quote
/* Tanix */
    bluetooth {
        compatible = "brcm,bcm43438-bt";
        clocks = <&rtc 1>;
        clock-names = "lpo";
        vbat-supply = <&reg_dldo1>;
        vddio-supply = <&reg_dldo1>;
        device-wakeup-gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */
        host-wakeup-gpios = <&r_pio 0 5 GPIO_ACTIVE_HIGH>; /* PL5 */
        shutdown-gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */
/* Vontar */
    bluetooth {
        clocks = <&rtc 1>;
/* transpeed */
    bluetooth {
        clocks = <&rtc CLK_OSC32K_FANOUT>;
        vddio-supply = <&reg_aldo1>;
        device-wakeup-gpios = <&pio 6 17 GPIO_ACTIVE_HIGH>; /* PG17 */
        host-wakeup-gpios = <&pio 6 16 GPIO_ACTIVE_HIGH>; /* PG16 */
        shutdown-gpios = <&pio 6 19 GPIO_ACTIVE_HIGH>; /* PG19 */
Expand
bluetooth.dtsUnavailable
Edited by firepower
Posted (edited)
for extra USB port.
Try adding this to your .dts
&ehci2 {
status = "okay";
&ohci2 {
status = "okay";
what is the &  for ?   overlay dont like it ?
I want to make the above in an overlay.
Edited by firepower
After playing around with overlays, seems they do not alter existing setting, only add new setting.
nothing changes by editing overlays and using sudo armbian-add-overlay /boot/dtb/allwinner/overlay/bluetooth.dts
Posted (edited)
Hello,
I want to activate the ethernet driver in Transpeed 8k H618 TV Box. Which patches should I apply. I have applied the following patches, but still it doesn't work. It is a custom 6.10 kernel that I only need ethernet for it.
0001-nvmem-sunxi_sid-add-sunxi_get_soc_chipid-sunxi_get_serial.patch  0505-net-phy-Add-support-for-AC200-EPHY.patch              0614-clk-sunxi-ng-ccu-sun6i-rtc-fix-32k-clk.patch
0002-drivers-pwm-Add-pwm-sunxi-enhance-driver-for-h616.patch          0531-iommu-sun50i-Allow-page-sizes-multiple-of-4096.patch  0615-drivers-iommu-sun50i-iommu-fix-iommu-on-h616.patch
0003-ASoC-AC200-Initial-driver.patch                                  0534-media-cedrus-Don-t-CPU-map-source-buffers.patch       Code-to-enable-Internal-OSC-Clock-Auto-Calibration.patch
0004-driver-allwinner-h618-emac.patch                                 0600-drivers-h616-wip-add-usb-emac2-support.patch
0504-mfd-add-AC200.patch                                              0606-dma-sun6i-dma-add-h616-support.patch
Edited by Javad Rahimipetroudi
Posted (edited)
Javad,
Have you patched your u-boot? You need these three patch files.
https://github.com/NickAlilovhttps://github.com/NickAlilovic/build/blob/v20241125/patch/u-boot/u-boot-sunxi/106-Add-int-phy-eth-H313-h616-with-AC300.patch
https://github.com/NickAlilovic/build/blob/v20241125/patch/u-boot/u-boot-sunxi/dts-Transpeed-8K618-T-Enable-Ethernet.patch
For your custom Kernel you need
https://github.com/NickAlilovic/build/blob/v20241125/patch/kernel/archive/sunxi-6.10/patches.armbian/arm64-dts-allwinner-h618-add-Transpeed-8K618-T-support.patch
The last two patches adds this to your u-boot and kernel DTS.
 	aliases {
		ethernet0 = &emac1;
 		ethernet1 = &sdio_wifi;
 		serial0 = &uart0;
&emac1 {
	pinctrl-names = "default";
	pinctrl-0 = <&rmii_pins>;
	phy-mode = "rmii";
	phy-handle = <&rmii_phy>;
	phy-supply = <&reg_aldo1>;
	allwinner,rx-delay-ps = <3100>;
	allwinner,tx-delay-ps = <700>;
	status = "okay";
&mdio1 {
	rmii_phy: ethernet-phy@0 {
		compatible = "ethernet-phy-ieee802.3-c22";
		reg = <0>;
You already have the EPHY 200 patched in your kernel. You have to edit your kernel config to enable it.
# MII PHY device drivers
CONFIG_AC200_PHY=m
# Multifunction device drivers
CONFIG_MFD_AC200=m
# PHY Subsystem
CONFIG_AC200_PHY_CTL=m
Edited by Nick A
Thanks Nick,
I didn't patched my U-Boot yet, is it required for the custom kernel?
I finally see something In the logs:
[    4.083865] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found
[    4.083897] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found
[    4.083908] dwmac-sun8i 5030000.ethernet: IRQ sfty not found
[    4.084838] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator
[    4.085323] dwmac-sun8i 5030000.ethernet: PTP uses main clock
[    4.085359] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 58000 (expect 50000)
[    4.090231] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported
[    4.090260] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported
[    4.090268] dwmac-sun8i 5030000.ethernet: COE Type 2
[    4.090277] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported
[    4.090285] dwmac-sun8i 5030000.ethernet: Normal descriptors
[    4.090293] dwmac-sun8i 5030000.ethernet: Chain mode enabled
But , now it shows the following error. From here https://linux-sunxi.org/Sun8i_emac It seems that the PHY regulator is not enabled:
[    4.323988] dwmac-sun8i 5030000.ethernet: EMAC reset timeout
[    4.329709] dwmac-sun8i 5030000.ethernet eth0: stmmac_dvr_remove: removing driver
[    4.358296] dwmac-sun8i 5030000.ethernet: probe with driver dwmac-sun8i failed with error -110
Posted (edited)
I was looking at the v4l2 patches for chromium. I think we can apply this to cedrus.
First, we apply these two patches.
https://github.com/armbian/build/blob/f55a87d469b0634f72bc857f773a52a466f66292/patch/kernel/archive/rockchip64-6.6/media-0001-dma-mapping-let-dma_alloc_noncontiguous-allow-DMA_AT.patch
https://github.com/armbian/build/blob/f55a87d469b0634f72bc857f773a52a466f66292/patch/kernel/archive/rockchip64-6.6/media-0002-Enable-non-coherent-dst-bufs-for-Hantro-V4L2-driver.patch
For the last patch we replace it with our own by editing /drivers/staging/media/sunxi/cedrus/cedrus_video.c and adding "dst_vq->allow_cache_hints = 1;".  You will see it at the very bottom of the cedrus_video.c file.
 https://github.com/armbian/build/blob/f55a87d469b0634f72bc857f773a52a466f66292/patch/kernel/archive/rockchip64-6.6/media-0003-Enable-non-coherent-dst-bufs-for-Rkvdec-V4L2-driver.patch
From 0000000000000000000000000000000000000000 Mon Sep 17 00:00:00 2001
Date: Fri, 3 Nov 2023 18:07:24 +0800
Subject: Enable non-coherent dst bufs for Rkvdec V4L2 driver
 drivers/staging/media/rkvdec/rkvdec.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/staging/media/rkvdec/rkvdec.c b/drivers/staging/media/rkvdec/rkvdec.c
index 84a41792cb4b..b35f7e1b8a20 100644
--- a/drivers/staging/media/rkvdec/rkvdec.c
+++ b/drivers/staging/media/rkvdec/rkvdec.c
@@ -755,6 +755,7 @@ static int rkvdec_queue_init(void *priv,
 	dst_vq->timestamp_flags = V4L2_BUF_FLAG_TIMESTAMP_COPY;
 	dst_vq->lock = &rkvdec->vdev_lock;
 	dst_vq->dev = rkvdec->v4l2_dev.dev;
+	dst_vq->allow_cache_hints = 1;
 	return vb2_queue_init(dst_vq);
Armbian
https://github.com/torvalds/linux/blob/master/drivers/staging/media/sunxi/cedrus/cedrus_video.c
	dst_vq->dev = ctx->dev->dev;
https://github.com/armbian/build/pull/5883
Then we have to create our own udev rules.
  Quote
Here is the udev rules I use for rk3566 to create v4l2 devices for chromium:
Expand
SUBSYSTEM=="video4linux", ATTR{name}=="rockchip,rk3568-vpu-dec", SYMLINK+="video-dec%n" SUBSYSTEM=="media", ATTR{model}=="hantro-vpu", SYMLINK+="media-dec%n"
This is from H6 dtsi... I think we need to add this to the h616 dtsi to get the hantro-vpu module to load.
https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi
		video-codec-g2@1c00000 {
			compatible = "allwinner,sun50i-h6-vpu-g2";
			reg = <0x01c00000 0x1000>;
			interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_VP9>, <&ccu CLK_VP9>;
			clock-names = "bus", "mod";
			resets = <&ccu RST_BUS_VP9>;
			iommus = <&iommu 5>;
if you see something like this in your dmesg then we are on right track.
https://forum.banana-pi.org/t/bpi-r2-pro-ubuntu-vpu-support-decode-and-encode/13776/16
  Quote
[147814.545292] hantro-vpu fdea0000.video-codec: registered rockchip,rk3568-vpu-dec as /dev/video0
Expand
We might need to use ubuntu's version of chromium? Not sure if the debian version is patched for v4l2.
https://github.com/saiarcot895/chromium-ubuntu-build/issues/65
Edited by Nick A
Posted (edited)
I think only the H6 SoC has a second VPU. This second VPU uses the hantro-vpu decoder for VP9. So this should work on H6.
Edited by Nick A
Posted (edited)
Is it possible to get stereo sound through LineOut?
I used Nick A's 20241007 image to set up my Vontar H618 as an internet radio player with digital LED clock, controlled by IR remote, thanks to Nick A, MMorales and everyone on this topic.
Everything works fine, except it plays mono.
Is there any way to fix this?
MPD is used as the player and I have tried different options in audio_output section on mpd.conf - no stereo,
here the current working config:
audio_output {
        type            "alsa"
        name            "My ALSA Device"
        device          "hw:0,0"
        format          "44000:16:2"
        mixer_type      "software"
        mixer_device    "plughw:audiocodec"
        mixer_control   "digital volume"
By the way all the mixers are mono, here the result of "amixer scontext" command:
Simple mixer control 'LINEOUT',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'LINEOUT volume',0
  Capabilities: volume volume-joined
  Capture channels: Mono
  Limits: 0 - 31
  Mono: 22 [71%]
Simple mixer control 'Left LINEOUT Mux',0
  Capabilities: enum
  Items: 'LOMixer' 'LROMixer'
  Item0: 'LOMixer'
Simple mixer control 'Left Output Mixer DACL',0
  Mono: Playback [on]
Simple mixer control 'Left Output Mixer DACR',0
  Mono: Playback [on]
Simple mixer control 'Right LINEOUT Mux',0
  Capabilities: enum
  Items: 'ROMixer' 'LROMixer'
  Item0: 'ROMixer'
Simple mixer control 'Right Output Mixer DACL',0
  Mono: Playback [on]
Simple mixer control 'Right Output Mixer DACR',0
  Mono: Playback [on]
Simple mixer control 'digital volume',0
  Limits: 0 - 63
  Mono: 0 [0%]
Edited by Alex2jf
text formatting and minor changes
The solution I found to enable stereo after googling for a few days is: editing a pulseaudio conf file
sudo nano /usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf
In this file look for a section starting with: [Mapping analog-mono] and ending with: priority=7
It will be about 6 or 8 lines long
Comment these lines out by preceding them with a " ; " (without the " " of course)
This will disable the analog-mono section
Save the file, sudo reboot and voila: your device profiles will contain stereo output (as well as multichanel, wich I did not try out)
And, even better, your sound IS in stereo
Regards,
aert077
https://forums.raspberrypi.com/viewtopic.php?t=293459
I found this.. I haven't tried it.
Thanks @Nick A
  Quote
Expand
Unfortunately, that's not it. There is only alsa, no installed pulseaudio and no pulseaudio conf file
I'll answer myself - looks like the solution is: start alsamixer and unmute “Left Lineout Mux” and “Right Lineout mux” with the cursor keys.
Here is a change to support 32k osc on H616/H618 by using the new driver clk/sunxi-ng/ccu-sun6i-rtc.c instead of retrofitting the code into drivers/rtc/rtc-sun6i.c
ccu-sun6i-rtc.c needs to be compiled into the kernel instead of being a module. Additionally it need to announce "osc32k-out" instead of "osc32k".
There is a diff file that changes the kernel config and the patches to perform and the patch file that changes the driver to place in patch/kernel/archive/sunxi-6.7/patches.armbian/
Move_32k_osc_diff.patchFetching info... drv-clk-sunxi-ng-use-osc32k-out.patchFetching info...
Hi
I'm trying to enable GPU on my custom kernel. I have applied a patch from Nick's repository, But when I allow `gpu` node in the Transpeed device tree, the kernel freezes here:
[    9.931994] sun50i-h616-codec 5096000.codec: Failed to register against DMAEngine
[    9.933237] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    9.947692] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    9.955742] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    9.964193] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    9.972000] sun8i-ce 1904000.crypto: Register cbc(aes)
[    9.977448] sun8i-ce 1904000.crypto: Register ecb(aes)
[    9.982650] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[    9.988522] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[    9.994324] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[   10.054128] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[   10.150367]  ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture
[   10.160265] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22
[   10.176581] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22
[   10.355412] videodev: Linux video capture interface: v2.00
[  OK  ] Reached target sound.target - Sound Card.
[   10.394078] Registered IR keymap rc-empty
[   10.398320] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[   10.405141] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input4
[   10.413088] sunxi-ir 7040000.ir: initialized sunXi IR driver
[   10.475252] panfrost 1800000.gpu: clock rate = 432000000
[   10.480726] panfrost 1800000.gpu: bus_clock rate = 200000000
When I disable the `gpu` node. The Xserver comes up. However, the videos are playing slowly and the CPU usage is 100%.
Any idea what could  be the problem?
Posted (edited)
Hi Javad, if you are playing youtube videos. 720p works fine for me. 1080 freeezes.
robertoj was able to get hardware video decocding working with ffmpeg-v4l2request. I haven't tested this method yet.
Edited by Nick A
