firepower Posted 8 hours ago Posted 8 hours ago (edited) There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them. https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/20/#findComment-217879 Edited 27 minutes ago by firepower 0 Quote
svyatoslav Posted 8 hours ago Posted 8 hours ago E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
svyatoslav Posted 8 hours ago Posted 8 hours ago firepower https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Vontar-h618_bookworm_edge_6.12.11_xfce_desktop.img.xz https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img.xz this? 0 Quote
Nick A Posted 7 hours ago Posted 7 hours ago (edited) @svyatoslav there’s android firmware but the Linux driver is old. Your dmesg doesn’t show any wifi info because there’s no driver. Unless you know how modify kernel drivers I would forget about it and use a usb wifi adapter. Edited 7 hours ago by Nick A 0 Quote
svyatoslav Posted 6 hours ago Posted 6 hours ago Unfortunately, the USB adapter was not detected either, there is still no sound. this image used: Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img 0 Quote
svyatoslav Posted 6 hours ago Posted 6 hours ago 2 часа назад, firepower сказал: There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them Please give me a link to your image. I'm trying to make a micro computer for my child, so I'm puzzled by remaking the console, if he wants to watch cartoons he'll figure it out. This is useful, the kid is 6 years old and he only watches cartoons, both on TV and on the phone. 0 Quote
979101h Posted 6 hours ago Posted 6 hours ago I have a box identical to the X98H. After installing the Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img.xz image compiled by Nike, the Ethernet port is not working. Here's the content returned by the dmesg command 0 Quote
kvvvp Posted 4 hours ago Posted 4 hours ago 1 час назад, svyatoslav сказал: the USB adapter was not detected either, t There is a stripped-down firmware in the Armbian images. Update it using armbian-config. Maybe the USB-WI-FI will work. But keep in mind that the updated firmware will take about 1 GB of memory. 0 Quote
svyatoslav Posted 4 hours ago Posted 4 hours ago (edited) Они видны, но не работают. root@x98h:~# lsusb Шина 005 Устройство 002: ID 8301:0089 Беспроводная клавиатура Hapurs HPBT05R 2.4 G Mini Wireless Touchpad Шина 005 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 003 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 004 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 002 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 006 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 001 Устройство 003: ID 148f:7601 Ralink Technology, Corp. Беспроводной адаптер MT7601U Шина 001 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 007 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Лучше всего работает: Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop., но нет Wi-Fi и звука. dmesg.txt Edited 3 hours ago by svyatoslav 0 Quote
svyatoslav Posted 3 hours ago Posted 3 hours ago (edited) 16.04.2025 в 05:10, firepower сказал: Вот полная прошивка brcm wifi BT. Я обнаружил, что она может быть полезна для других устройств wifi BT. no access all links to your images are not available Edited 3 hours ago by svyatoslav 0 Quote
svyatoslav Posted 2 hours ago Posted 2 hours ago doesn't want to get ready, tell me where to go? E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Exiting with error 43 [ at /home/toor/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 install_host_side_packages() --> lib/functions/host/host-utils.sh:81 install_host_dependencies() --> lib/functions/host/prepare-host.sh:304 prepare_host_noninteractive() --> lib/functions/host/prepare-host.sh:92 do_with_logging() --> lib/functions/logging/section-logging.sh:81 prepare_host() --> lib/functions/host/prepare-host.sh:17 prepare_host_init() --> lib/functions/main/start-end.sh:64 main_default_start_build() --> lib/functions/main/start-end.sh:17 do_with_default_build() --> lib/functions/main/default-build.sh:41 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
Nick A Posted 2 hours ago Posted 2 hours ago @svyatoslav are you using my latest build? git clone https://github.com/NickAlilovic/build.git --branch v20250306 0 Quote
svyatoslav Posted 1 hour ago Posted 1 hour ago 18 минут назад, Nick A сказал: git-клон https://github.com/NickAlilovic/build.git --branch v20250306 no git clone https://github.com/armbian/build 0 Quote
svyatoslav Posted 1 hour ago Posted 1 hour ago git-клон https://github.com/NickAlilovic/build.git --branch v20250306 same mistakes [🌱] Installing host-side packages [ bison libc6-dev make dpkg-dev gcc ccache dwarves flex imagemagick libbison-dev libelf-dev libfdt-dev libfile-fcntllock-perl libmpc-dev libfl-dev lz4 libncurses-dev libssl-dev libusb-1.0-0-dev ntpdate patchutils pkg-config pv arch-test swig uuid-dev zlib1g-dev file tree expect colorized-logs zip pigz pbzip2 lzop zstd aria2 axel parallel rdfind libpython3-dev libffi-dev libgnutls28-dev gcc-aarch64-linux-gnu libc6-amd64-cross busybox gcc-arm-linux-gnueabi gcc-or1k-elf ] [🔨] E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Exiting with error 43 [ at /home/toor/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 install_host_side_packages() --> lib/functions/host/host-utils.sh:81 install_host_dependencies() --> lib/functions/host/prepare-host.sh:301 prepare_host_noninteractive() --> lib/functions/host/prepare-host.sh:92 do_with_logging() --> lib/functions/logging/section-logging.sh:81 prepare_host() --> lib/functions/host/prepare-host.sh:17 prepare_host_init() --> lib/functions/main/start-end.sh:64 main_default_start_build() --> lib/functions/main/start-end.sh:17 do_with_default_build() --> lib/functions/main/default-build.sh:41 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] [🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-03e98215-6ec0-4f62-aee5-bd34c6d02252.log.ans ] [🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [🌿] Share log manually: [ curl --data-binary @output/logs/log-build-03e98215-6ec0-4f62-aee5-bd34c6d02252.log.ans https://paste.armbian.com/log ] [🌿] Share log manually: [ curl --data-binary @output/logs/log-build-03e98215-6ec0-4f62-aee5-bd34c6d02252.log.ans https://paste.armbian.de/log ] [🌿] Share log manually: [ curl --data-binary @output/logs/log-build-03e98215-6ec0-4f62-aee5-bd34c6d02252.log.ans https://paste.next.armbian.com/log ] [🌿] Share log manually: [ curl --data-binary @output/logs/log-build-03e98215-6ec0-4f62-aee5-bd34c6d02252.log.ans https://paste.armbian.eu/log ] toor@orangepi3:~/build$ 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago (edited) Try installing these yourself before you build.. the build system recommends Ubuntu Jammy 22.04.x sudo apt install bison libc6-dev make dpkg-dev gcc ccache dwarves flex imagemagick libbison-dev libelf-dev libfdt-dev libfile-fcntllock-perl libmpc-dev libfl-dev lz4 libncurses-dev libssl-dev libusb-1.0-0-dev ntpdate patchutils pkg-config pv arch-test swig uuid-dev zlib1g-dev file tree expect colorized-logs zip pigz pbzip2 lzop zstd aria2 axel parallel rdfind libpython3-dev libffi-dev libgnutls28-dev gcc-aarch64-linux-gnu libc6-amd64-cross busybox gcc-arm-linux-gnueabi gcc-or1k-elf Edited 1 hour ago by Nick A 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago (edited) @979101h I have the original X98H. I'll test the image again on my box. Edit: Just tested the server image on my box. I have no issues with Ethernet. I have all the same messages but your missing. end0:Link is up - 100Mbps/Full - flow control rx/tx Edited 29 minutes ago by Nick A 0 Quote
svyatoslav Posted 1 hour ago Posted 1 hour ago [🔨] E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
svyatoslav Posted 1 hour ago Posted 1 hour ago (edited) может быть проблема в том, что я запускаю сборку на orange3.? there is no other option, only orange pi3 with armbian installed. Edited 1 hour ago by svyatoslav 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago (edited) You need a PC... it would probably take days to compile a build on a SBC. Edited 51 minutes ago by Nick A 0 Quote
firepower Posted 27 minutes ago Posted 27 minutes ago @svyatoslav https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/20/#findComment-217879 0 Quote
