Nick A Posted August 11 Share Posted August 11 Hi kazekami, Try adding this to your .dts &ehci2 { status = "okay"; }; &ohci2 { status = "okay"; }; 1 Quote Link to comment Share on other sites More sharing options...
Johan S Posted August 11 Share Posted August 11 2 hours ago, Nick A said: Try the firmware from https://github.com/LibreELEC/brcmfmac_sdio-firmware brcmfmac4334-sdio.txt brcmfmac4334-sdio.bin Rename brcmfmac4334-sdio.bin to brcmfmac4334-sdio.transpeed,8k618-t.bin or create a link. copy the files into your /lib/firmware/brcm/ directory. Thank @Nick A! The internal wifi adapter is correctly loaded and working - thank you Btw i noticed that the brcmfmac4334-sdio.bin in the git repo is identical to the brcmfmac4334-sdio.bin file already contained in the /lib/firmware/brcm directory. Maybe the underlying issue was that my system was configured to look for the brcmfmac4334-sdio.transpeed,8k618-t.bin instead of just the generic brcm4334 driver? Anyway, everything works and the tvbox is surprising useful for light desktop and server applications (given it only cost about 26 bucks! What a deal) 0 Quote Link to comment Share on other sites More sharing options...
hayat Sınav Posted August 12 Share Posted August 12 Quote Hi @Nick A and friends, I got my own Transpeed 8K earlier this week (4GB ram / 64GB emmc). I am including a picture with the top off below. 1) I first tried to install the MiniArch OS of WarpMe. I used the VONTAR image as recommended in this thread. Almost everything worked out of the box including WiFi. - HDMI: Display works, sound not tested - Ram: MiniArch correctly detects all 4GB of ram. - EMMC: For some reason, I could not get the emmc to work. First I tried to use the tool supplied by MiniArch to flash the OS to emmc, but it just hangs indefinitely. Then I tried to manually format / partition the emmc with fdisk, but everytime i try to write a partition table to mmcblk2 (both GPT and MBR), my system would just hang indefinitely - attempting to mount /dev/mmcblk2 produce the same outcome. I manage to somehow format the emmc. - WiFi: The only other (minor) issue i had with MiniArch is that it takes about 2 min for the OS to properly load the wifi drivers (see output from dmesg for reference). I didn't spend so more time on MiniArch because I'd much rather use Armbian. [ 67.908595] cfg80211: failed to load regulatory.db [ 69.615347] brcmfmac mmc3:0001:1: loading /lib/firmware/brcm/brcmfmac4334-sdio.clm_blob failed with error -22 [ 69.625299] brcmfmac mmc3:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -22 [ 69.635482] brcmfmac mmc3:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac4334-sdio.clm_blob [ 131.233673] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 131.233699] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2) [ 131.234035] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e 2) I then tried the Armbian-20240726-unofficial_24.8.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_server.img.tar.xz prepared by Nick. - I had to unpack the xz file before flashing with balenaEtcher to get it to work correctly. The image works really well on my Transpeed8k. - HDMI: Display works, sound not tested - Ram: Correctly detects all 4GB - EMMC: It works! I ran armbian-install and succesfully transferred to OS to emmc and I am booting from emmc without SD-card! - WiFi: does not work out of the box (dmesg output below). I have added a wifi dongle (RealTek 8188) and it worked right away. I will see if i can get the internal wifi to work. - DE: I installed xfce4 and it works really well on the transpeed. - Other: I noticed that the 7-segment display (time display) on the device is driven by a FD650 chip that communicates over i2c. brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3 brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin failed with error -2 brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2 brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50 John S. I have the vontar model identical to the box. The only difference is John S. Your box is v10, mine is v11. So far I've only been able to launch miniarc. I can't boot the Armbian images Nick gave me, it stays on a black screen. Does anyone have any ideas about this? 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted August 12 Share Posted August 12 (edited) Hi Hayat, If you can boot Miniarch then you can boot Armbian. You just need to port over the vontar.dts and defconfig for u-boot and kernel from Miniarch to my Armbian build. I posted the steps in the previous page. I don't have a vontar box so I can't help you with testing. Plus I'm too busy with work right now. https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-h616/files/160-add-vontar-h618-defconfig.patch https://github.com/warpme/minimyth2/blob/master/script/kernel/linux-6.10/files/0647-arm64-dts-allwinner-h618-add-vontar-h618-TVbox.patch https://github.com/NickAlilovic/build Edited August 12 by Nick A 1 Quote Link to comment Share on other sites More sharing options...
Johan S Posted August 12 Share Posted August 12 5 hours ago, hayat Sınav said: John S. I have the vontar model identical to the box. The only difference is John S. Your box is v10, mine is v11. So far I've only been able to launch miniarc. I can't boot the Armbian images Nick gave me, it stays on a black screen. Does anyone have any ideas about this? Hi Hayat, Just to confirm: I was able to boot up the image Nick provided without any further changes / patching. - I used the "server" image of release V20240726 (https://github.com/NickAlilovic/build/releases/tag/v20240726) - I first unpacked the .xz file and then I flashed the .img file using balenaEtcher on a 16GB SD card. *** Notice, initially I flashed the compressed .img.xy. The operation would complete, but when I tried to boot up, the boot process would fail in a similar manner to what you describe (black screen). I noticed that balenaEtcher did not correctly create a bootable system on the SD card. After unpacking the .xz file and flashing the .img file directly with balenaEtcher everything went smoothly. Good luck! 0 Quote Link to comment Share on other sites More sharing options...
hayat Sınav Posted August 13 Share Posted August 13 Thank you. The problem was caused by my SD card. Gnome and xfce desktops work fine now. I have two different problems right now. First of all, while the system is running on the SD card, I change the name of the .bin file and copy it to the brcm folder with root permission. Even though I turn it off and on again, it doesn't see wifi. Do I need to add Armbian before compiling? My second problem is that the device does not boot when I install it on a 64GB mmc. I need support with MMC. Sorry for my bad english. 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted August 14 Share Posted August 14 (edited) Hi Hayat, I think you still need the brcmfmac4334-sdio.txt in the brcm folder. Right now it's called "brcmfmac4334-sdio.rockchip,rk3318-box.txt". The rockchip does the opposite and renames the .txt file instead of the .bin file. If you can post your boot log we can figure it out. You might have a different WIFI chip. For MMC it could be something simple or it could be your dts. There are differences in the Transpeed and Vontar dts settings. On the Transpeed box I have to set cd-gpios to PI16. +&mmc0 { + vmmc-supply = <®_dldo1>; + cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ + bus-width = <4>; + status = "okay"; +}; On the Vontar box this is set to broken-cd. You just need to change that one line in my u-boot and kernel .dts patches. +&mmc0 { + vmmc-supply = <®_dldo1>; + broken-cd; + bus-width = <4>; + status = "okay"; +}; git clone https://github.com/NickAlilovic/build.git edit these two files. ~/build/patch/kernel/archive/sunxi-6.7/patches.armbian/dts-allwinner-h618-add-Transpeed-8K618-T-TV-box.patch ~/build/patch/u-boot/u-boot-sunxi/dts-Transpeed-8K618-T-Add-Transpeed-8K618-T-board-support.patch ./compile.sh Not sure if you can still extract your original android dts. Your android dts can help figure out your gpio settings. Edited August 14 by Nick A 0 Quote Link to comment Share on other sites More sharing options...
Johan S Posted August 14 Share Posted August 14 Hi Hayat, Just out of curiosity could you share the following: 1) A picture of TV box' PCB and picture where you zoom in on the WiFi module (it is probably a module with a metal EMC-shield covering it). 2) Regarding WiFi: Could you run dmesg | grep brc and share output. Then run ip link and share output. 3) Regarding EMMC, could you run the commands below and share output sudo lsblk df -h On my system, the emmc drive showed up as mmcblk2. I was trying (unsuccesfully) to load MiniArch on to the emmc, in the process, I first formatted the emmc to get rid of the android OS files using "fdisk /dev/mmcblk2" and interacting with the on-screen menu, but in MiniArch I was never able to complete the formatting operation, my system would hang every time I asked fdisk to create a new partion table. When I eventually booted up Nick's Armbian image, I was able to install to EMMC directly using the Armbian tool sudo armbian-install 0 Quote Link to comment Share on other sites More sharing options...
hayat Sınav Posted August 14 Share Posted August 14 I can't attend right now because I'm at work. I'll try your suggestions. I am adding photos. Actually, Vontar and Transpeed boxes are exactly the same, only the outer shell and names are different. 0 Quote Link to comment Share on other sites More sharing options...
hayat Sınav Posted August 14 Share Posted August 14 I was able to solve the problems. I couldn't format MMC from disk management, it kept giving errors. I went in with the MMC install option from armbian-install and formatted it, then canceled it before starting the installation. I formatted the mmc in ext4 format from disk management and started it. Then I installed it to mmc again with armbian install. I am currently using it by booting from mmc. After installing mmc, when I copied the wifi files to the brcm folder, wifi worked too. It's working fine now and I'm installing the klipper. thank you very much for everything 0 Quote Link to comment Share on other sites More sharing options...
L Jumadi Posted August 29 Share Posted August 29 Hi, I have Tx3 mini-A (seems tanix clone as I not found officially same spec) that have H616 chip. i already open and setting serial cable to see serial message, I try with vontar miniarch it say DRAM not supported. When I try normal boot serial screen show DRAM Type = 8 (LPDDR4) so I try with Orange Pi3 setup it can boot but seems stuck, I try with HDMI screen it show 3 penguin there. Still dont know next move, I include screen shoot on original android serial and on Orangepi3 miniarch. Sure want armbian can manage my box with wifi 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 2 Share Posted September 2 (edited) Hi L Jumadi You need the correct defconfig for your u-boot. You can use sunxi-fw to extract your DRAM setup. https://github.com/apritzel/sunxi-fw You can use an android update firmware or your extracted boot0. Also, you can run a statically linked sunxi-fw on the boot block device from Android, like "sunxi-fw info -v /dev/block/mmcblk1", to dump the DRAM parameters (if you have root there) for example Orangepie zero 3 has lpddr4. CONFIG_DRAM_SUN50I_H616_DX_ODT=0x07070707 CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e CONFIG_DRAM_SUN50I_H616_ODT_EN=0xaaaaeeee CONFIG_DRAM_SUN50I_H616_TPR6=0x44000000 CONFIG_DRAM_SUN50I_H616_TPR10=0x402f6663 CONFIG_DRAM_SUN50I_H616_TPR11=0x24242624 CONFIG_DRAM_SUN50I_H616_TPR12=0x0f0f100f CONFIG_MACH_SUN50I_H616=y CONFIG_SUNXI_DRAM_H616_LPDDR4=y CONFIG_DRAM_CLK=792 You can get more information on your box by extracting your android dts. Sometimes you can find the dram settings in your dts. Edited September 3 by Nick A 0 Quote Link to comment Share on other sites More sharing options...
kazekami Posted September 4 Share Posted September 4 (edited) Hi @Nick A. Thank you for answering my questions. Edited September 4 by kazekami 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted September 5 Share Posted September 5 (edited) Your welcome Kazekami. If you have a working box. Make a board config. Post your board config, u-boot defconfig, u-boot dts and linux kernel dts. I can make a patch for you and add it to my build. It will help others with the same box as yours. https://github.com/NickAlilovic/build/blob/main/config/boards/transpeed-8k618-t.wip Edited September 5 by Nick A 1 Quote Link to comment Share on other sites More sharing options...
L Jumadi Posted Tuesday at 04:16 AM Share Posted Tuesday at 04:16 AM @Nick A thanks, I wrong thought I already passed DRAM problem, will try to provide the info soon when Im ready 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted Tuesday at 06:28 PM Share Posted Tuesday at 06:28 PM (edited) Had some time to update armbian and the linux kernel. If anyone wants to test my latest Armbian 24.11.0 with 6.9.12 kernel here are the links. https://github.com/NickAlilovic/build/releases/tag/v20240909 https://github.com/NickAlilovic/build/tree/v20240909 Edited Tuesday at 06:58 PM by Nick A 0 Quote Link to comment Share on other sites More sharing options...
L Jumadi Posted Wednesday at 08:32 AM Share Posted Wednesday at 08:32 AM Hi @Nick A I manage extract dts using Android Image Kitchen, its named dtb. I already try to read using dtc -O dts dtb and found complete info about my hardware but still confuse with next move where to put setting or compiling uboot or image. Hope its using generic driver already have in armbian dtb 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted Wednesday at 12:49 PM Share Posted Wednesday at 12:49 PM (edited) I see two different dram settings in your dtb. Not sure which is the correct one. Lets try the first one. You can edit the values in my u-boot defconfig patch. git clone https://github.com/NickAlilovic/build.git --branch v20240909 --single-branch cd build/patch/u-boot/u-boot-sunxi pico configs-Transpeed-8K618-T-Add-Transpeed-8K618-T-board-support.patch dram_para1 { device_type = "dram_para1"; dram_clk = <0x288>; dram_type = <0x03>; dram_dx_odt = <0x3030303>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0x1c1c>; dram_odt_en = <0x01>; dram_para1 = <0x30fb>; dram_para2 = <0x00>; dram_mr0 = <0x840>; dram_mr1 = <0x04>; dram_mr2 = <0x08>; dram_mr3 = <0x00>; dram_mr4 = <0x00>; dram_mr5 = <0x00>; dram_mr6 = <0x00>; dram_mr11 = <0x00>; dram_mr12 = <0x00>; dram_mr13 = <0x00>; dram_mr14 = <0x00>; dram_mr16 = <0x00>; dram_mr17 = <0x00>; dram_mr22 = <0x00>; dram_tpr0 = <0xc0001305>; dram_tpr1 = <0x00>; dram_tpr2 = <0x00>; dram_tpr3 = <0x00>; dram_tpr6 = <0x33808080>; dram_tpr10 = <0x2f0006>; dram_tpr11 = <0xffffdddd>; dram_tpr12 = <0xfedf7657>; dram_tpr13 = <0x40>; }; dram { compatible = "allwinner,dram"; clocks = <0xd9>; clock-names = "pll_ddr"; dram_clk = <0x2b8>; dram_type = <0x08>; dram_zq = <0x3f3fdd>; dram_odt_en = <0xffffeeee>; dram_para1 = <0x30fa>; dram_para2 = <0x00>; dram_mr0 = <0x00>; dram_mr1 = <0x34>; dram_mr2 = <0x1b>; dram_mr3 = <0x33>; dram_tpr0 = <0x00>; dram_tpr1 = <0x00>; dram_tpr2 = <0x00>; dram_tpr3 = <0x00>; dram_tpr4 = <0x00>; dram_tpr5 = <0x00>; dram_tpr6 = <0x39808080>; dram_tpr7 = <0x00>; dram_tpr8 = <0x00>; dram_tpr9 = <0x00>; dram_tpr10 = <0x402f6663>; dram_tpr11 = <0x31313031>; dram_tpr12 = <0xd0d0c0e>; dram_tpr13 = <0x60>; linux,phandle = <0x17d>; phandle = <0x17d>; device_type = "dram"; dram_dx_odt = <0xc0c0c0c>; dram_dx_dri = <0xe0e0e0e>; dram_ca_dri = <0xe0b>; dram_mr4 = <0x03>; dram_mr5 = <0x00>; dram_mr6 = <0x00>; dram_mr11 = <0x04>; dram_mr12 = <0x72>; dram_mr13 = <0x00>; dram_mr14 = <0x09>; dram_mr16 = <0x00>; dram_mr17 = <0x00>; dram_mr22 = <0x24>; }; dram_clk = <0x288>; 288 hex = 648 https://www.rapidtables.com/convert/number/hex-to-decimal.html?x=288 It should be 8 or 4 digits. I added a 0 to the beginning of DX_ODT and DX_DRI. dram_dx_odt = <0x3030303>; CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303 Change my defconfig to these values. +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x0c0c0c0c +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0b +CONFIG_DRAM_SUN50I_H616_TPR0=0xc0001305 +CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0006 +CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd +CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7657 Now you compile a new image. You will find the image in output/images. cd ../../../ ./compile.sh build BOARD=transpeed-8k618-t BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED=browsers DESKTOP_ENVIRONMENT=xfce DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=bookworm cd output/images If your box is really LPDDR4. Then change these lines. +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303 +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1f12 +CONFIG_DRAM_SUN50I_H616_TPR0=0xc0001002 +CONFIG_DRAM_SUN50I_H616_TPR10=0x2f1107 +CONFIG_DRAM_SUN50I_H616_TPR11=0xddddcccc +CONFIG_DRAM_SUN50I_H616_TPR12=0xeddc7665 +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_DRAM_CLK=648 To +CONFIG_DRAM_SUN50I_H616_DX_ODT=0x07070707 +CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e +CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e +CONFIG_DRAM_SUN50I_H616_ODT_EN=0xffffeeee +CONFIG_DRAM_SUN50I_H616_TPR6=0x402f6663 +CONFIG_DRAM_SUN50I_H616_TPR10=0x402f6663 +CONFIG_DRAM_SUN50I_H616_TPR11=0x31313031 +CONFIG_DRAM_SUN50I_H616_TPR12=0x0d0d0c0e +CONFIG_MACH_SUN50I_H616=y +CONFIG_SUNXI_DRAM_H616_LPDDR4=y +CONFIG_DRAM_CLK=696 Because you are adding another line of code @@ -0,0 +1,27 @@ should be @@ -0,0 +1,28 @@. Or you can follow these steps to create your own patch. Edited Wednesday at 08:10 PM by Nick A 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted Thursday at 03:41 PM Share Posted Thursday at 03:41 PM (edited) I want to install armbian on TV box. I can buy Tanix TX68 4GB 64GB H618 for a good price. It has 1 USB3 and 2 USB2 which would be useful. Anyone have experience with installing Armbian on this? It should be similar to other tv boxes in this thread? Edited Thursday at 05:42 PM by firepower 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted Thursday at 04:20 PM Share Posted Thursday at 04:20 PM (edited) ORIGINAL firmware for Tanix TV Boxs https://www.tanixtvbox.com/firmware-centre/ Russian Site with Info about TV box Tanix TX68 http://nskhuman.ru/allwinner/tanix.php?np=7 fdt.zip Edited Thursday at 06:03 PM by firepower 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted Thursday at 06:02 PM Share Posted Thursday at 06:02 PM (edited) TV box X98H Pro on Android 12 http://nskhuman.ru/allwinner/x98hpro.php TV box T95Z Plus on Android 12 http://nskhuman.ru/allwinner/t95zplus.php TV box Transpeed/HK1RBox/Vontar H618 http://nskhuman.ru/allwinner/krugh618.php Edited Thursday at 06:03 PM by firepower 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted Thursday at 06:28 PM Share Posted Thursday at 06:28 PM (edited) My transpeed image should boot on all the boxes you listed. X98H PRO: you need to edit the transpeed dts and change the gpio for mmc0. Android DTS. cd-gpios = <0x00000023 0x00000005 0x00000006 0x00000011>; Armbian/Linux DTS cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ This shows a picture of the x96. I have the non-pro version of the X98H and I'm pretty sure it's a AIC8800 chip. http://nskhuman.ru/allwinner/x98hpro.php?np=3 you might have a hard time getting the AIC8800 driver for wifi to work. I haven't spent a lot of time on it. https://github.com/radxa-pkg/aic8800/tree/3.0%2Bgit20240327.3561b08f-2 I'm working on the 6.10 kernel right now. I'm going to release a custom dts for X98H when I'm done. Edited Thursday at 11:29 PM by Nick A 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted yesterday at 05:08 AM Share Posted yesterday at 05:08 AM (edited) Would AW859 firmware info help ? https://github.com/orangepi-xunlong/firmware wifi_2355b001_1ant.ini T95ZPLUS H618 2+16G WIFI:AW869A working Wifi and BT for armbian https://github.com/LYU4662/aic8800-sdio-linux-1.0 https://github.com/OpenIPC/aic8800 Edited yesterday at 12:48 PM by firepower 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted 21 hours ago Share Posted 21 hours ago (edited) https://github.com/warpme/minimyth2 close to to the bottom of the page. Allwinner H6 OrangePi-3 LTS not works (aw859a) Allwinner H616 OrangePi-Zero2 works (aw859a@SDIO) Allwinner H618 OrangePi-Zero3 works (uwe5622a@SDIO) I guess uwe5622 and aw859a are the same. OrangePi 3 LTS does not use SDIO. I'm pretty sure T95Z Plus does. Edited 20 hours ago by Nick A 0 Quote Link to comment Share on other sites More sharing options...
