Nick A Posted October 1, 2024 Posted October 1, 2024 (edited) My 6.10 kernel needs more work. The patches for Ethernet is broken. I think the hdmi works on my box tho. I would stick with 6.9 for now. Edited October 1, 2024 by Nick A 0 Quote
L Jumadi Posted October 2, 2024 Posted October 2, 2024 (edited) @MMorales I maybe have same problem but not aware as I just unplug adaptor to switch off, and when stuck just replug then its normal boot.. so I guess it only happen intermittently and because some of electronic component not warmed up Edited October 2, 2024 by L Jumadi 0 Quote
L Jumadi Posted October 2, 2024 Posted October 2, 2024 @Nick A when I try your 6.10 my HDMI works, one ethernet patches I disable because conflict with my defconfig patch but my ethernet still work. Then I patch wifi also work.. need back to 6.9 just because no header to compile openvfd :) 0 Quote
firepower Posted October 2, 2024 Posted October 2, 2024 (edited) I got wifi working by making link > file in /lib/firmware/brcm brcmfmac4330-sdio.tanix,tx6s.bin > brcmfmac4330-sdio.bin brcmfmac4330-sdio.tanix,tx6s.txt > brcmfmac-ap6330-sdio.txt Also have Cinnamon Desktop/Menu now working after purge and reinstall of cinnamon. Still need to get BlueTooth and Ethernet working. Thanks @Nick A Edited October 3, 2024 by firepower 0 Quote
MMorales Posted October 2, 2024 Posted October 2, 2024 @Nick A thanks for the info and all your work. Do you know how we can get 6.9.12 kernel headers ? 0 Quote
MMorales Posted October 2, 2024 Posted October 2, 2024 Some animations modifying glyphs.c in the openvfs driver. I let this here for myself or anyone who looks for this kind of silly thing. glyphs.hanimaciones.py 0 Quote
firepower Posted October 3, 2024 Posted October 3, 2024 @MMorales Your LED Display work is really cool and nerdy 🤯😎🤓 0 Quote
MMorales Posted October 3, 2024 Posted October 3, 2024 (edited) Tested in Transpeed 8k H618 4g 64g & Vontar 6k h618 4g 32g @Nick A As we talk, here are the final "howto" to make it working leds display with openvfd. If you find any problem tell me. First go to armbian-config to change some kernel with has his own headers available like 6.10.9 (i had problem with rebooting with 6.7.12) configure an internet connection unpack the attached file to root dir / cd /linux_openvfd cp openvfd.dts /boot/dtb/allwinner/overlay/ armbian-add-overlay /boot/dtb/allwinner/overlay/openvfd.dts reboot ln -sf /boot/System.map-$(uname -r) /lib/modules/$(uname -r)/build/System.map cd cd /linux_openvfd/driver make -j 4 depmod -a make modules_install modprobe openvfd cd .. chmod +x OpenVFDService cp OpenVFDService /usr/sbin/ cp openvfd.service /etc/systemd/system/openvfd.service #apt install python3-psutil systemctl enable openvfd.service systemctl start openvfd.service After this, openvfd is working but if you want my scroll.py as a service uncomment in openvfd.service and comment the existing one. #ExecStart=/bin/sh -c '[ `cat /proc/device-tree/openvfd/compatible` = "open,vfd" ] && /sbin/modprobe openvfd; python3 /linux_openvfd/scroll.py' Correct openvfd.dts, some compiling fixes and extra glyphs for cool animations added to this file. linux_openvfd.zip @Nick A Please let me know if you make a new release with kernel 6.9.12 with this working cos now i made my server but no hdmi and no ethernet in 6.10. Edited October 4, 2024 by MMorales 2 Quote
MMorales Posted October 4, 2024 Posted October 4, 2024 (edited) @Nick A This is a compiled version of OpenVFDService for controlling the brightness. Usage: OpenVFDService [-t] [-dt TYPE] [-h] -s USER_STRING Run OpenVFDService in custom string mode. Displays the USER_STRING on the screen. -ss SECONDARY_USER_STRING Display a smaller secondary string in addtion to USER_STRING. -b Brightness [0-7] <----------------------------- -t Run OpenVFDService in display test mode. -dm Run OpenVFDService in display demo mode. -dt N Specifies which display type to use. -co N... < D HH:MM > Order of display chars. Valid values are 0 - 6. (D=dots, represented by a single char) -h This text. OpenVFDService_with_Brightness_control.zip Edited October 4, 2024 by MMorales 0 Quote
firepower Posted October 4, 2024 Posted October 4, 2024 (edited) I started following you instructions for openvfd. clone git and changed the kernel and reboot. but i dont have ethernet and it kept trying to connect and time out. ended up reloading image on SDCARD. lol think i found the reason why cinnamon fails to load menu. cinnamon app does not exist zero size. xfce4-about.desktop think i will reload image again and work out exactley th problem with cinnamon Edited October 4, 2024 by firepower 0 Quote
MMorales Posted October 4, 2024 Posted October 4, 2024 @firepower my instructions dont tell u to do any git clone. only unpack the zip file. And you have another type of machine i dont know about your environment. If you have kernel header installed u could follow the howto. 0 Quote
firepower Posted October 4, 2024 Posted October 4, 2024 (edited) starting from git clone https://github.com/augin/linux_openvfd i did this. it not problem i was just testing , my image is still not fully working so just playing around with it trying to learn more about armbian. but breaking it has given more info about cinnamon problem which i want to fix. as first fix was more by brute force purge and reinstall cinnamon which is not needed but uninstal and reinstall menu applet. I need to check android DTS and compare with my Armbian DTS , think some gpio / uarts need fixing for ethernet and Bluettoth but im noob so lots to learn. Also need faster SD card as one i have are slow. I gone back to testing miniarch image also, and ethernet does work with it. Edited October 5, 2024 by firepower 0 Quote
L Jumadi Posted October 5, 2024 Posted October 5, 2024 (edited) @MMorales better you suggest this to liberman github, so many other get benefit Edit: Nvm, Sorry I thought you make the correction of the service Edited October 5, 2024 by L Jumadi wrong perception 0 Quote
rafman Posted October 9, 2024 Posted October 9, 2024 For Transpeed 8k in order to make your IR remote to work with Armbian (it may works and with other H618 boxes, but i test it only on Transpeed 8k) do the following steps: 1> sudo apt-get install ir-keytable 2> copy the attached file transpeed-8k.toml to /etc/rc_keymaps/protocols/ 3> add the following line to your /etc/rc.local ir-keytable -p NEC -w /etc/rc_keymaps/protocols/transpeed-8k.toml It works with mpv / vlc /celluloid. Note: you can add any remote you have to your box by playing with ir-keytable is a very useful tool. transpeed-8k.toml 4 Quote
MMorales Posted October 9, 2024 Posted October 9, 2024 nice! @rafman works perfect!. I configured a mini remote for switching led display info and control the brightness. And only Bluetooth to have everything configured. 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 For the Bluetooth : (my tv box is Transpeed 8k) I compile @Nick A gihub trunk with 6.7.12 kernel. I am still looking for a solution for Bluetooth. My dmesg shows : [ 17.147966] Bluetooth: RFCOMM TTY layer initialized [ 17.148004] Bluetooth: RFCOMM socket layer initialized [ 17.148113] Bluetooth: RFCOMM ver 1.11 [ 19.176140] Bluetooth: hci0: command 0x0c24 tx timeout [ 19.176239] Bluetooth: hci0: Opcode 0x0c24 failed: -110 [ 21.188126] Bluetooth: hci0: Opcode 0x0c24 failed: -110 [ 21.188163] Bluetooth: hci0: command 0x0c24 tx timeout [ 23.202926] Bluetooth: hci0: Opcode 0x0c24 failed: -110 [ 23.203000] Bluetooth: hci0: command 0x0c24 tx timeout [ 25.218922] Bluetooth: hci0: command 0x0c24 tx timeout [ 25.218925] Bluetooth: hci0: Opcode 0x0c24 failed: -110 [ 37.187145] Bluetooth: hci0: command 0x0c24 tx timeout [ 37.187148] Bluetooth: hci0: Opcode 0x0c24 failed: -110 [ 39.203189] Bluetooth: hci0: command 0x0c24 tx timeout [ 39.203190] Bluetooth: hci0: Opcode 0x0c24 failed: -110 Also kernel asks for an additional firmware blob file: (but i can't find it) [ 6.169613] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2 I already have place theese 2 files from (https://github.com/LibreELEC/brcmfmac_sdio-firmware) on my /lib/firmware and wifi seems to work (wlan0 is active) . brcmfmac4334-sdio.bin brcmfmac4334-sdio.txt as -rw-r--r-- 1 rafman rafman 398010 Oct 9 19:09 brcmfmac4334-sdio.transpeed,8k618-t.bin -rw-r--r-- 1 rafman rafman 2404 Oct 9 19:10 brcmfmac4334-sdio.txt My chip is this PS: @MMorales An other problem that i had, is when i switched to other kernel (like 6.10.9) from armbian-config or from command line, the system breaks and does not boot at all on next reboot. After that i found kernel headers for 6.7.12 here: https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-headers-edge-sunxi64/linux-headers-edge-sunxi64_24.5.1_arm64__6.7.12-Sdacf-D440d-Pfa2b-Cdb7aH5c21-HK01ba-Vc222-Bf15a-R448a.deb and i was able to compile openvfd (with a small modification of openvfd_drv.c --> :629:35 by place a cast to (void *) NOW i can see the time on my Transpped LCD screen and i am testing further the driver. 0 Quote
MMorales Posted October 10, 2024 Posted October 10, 2024 (edited) @rafman I had the same problem as you installing 6.10.9 but really its works, the problem is the hdmi is not working. so its boots but you only can see it if you connect it by serial. Anyware @Nick A deployed a new image wich works with 6.10.9. I tested today and hdmi and network works but we have to do the known tricks to enable wifi and the rest of the things. https://github.com/NickAlilovic/build/releases/tag/20241007 here you can download it and its headers are available too. Its fresh For other side... i want to enable sensors too. Looking on the android dts i can found this but i dont know very well how to make an overlay and make sensors work. thermal-zones { cpu_thermal_zone { polling-delay-passive = <0x1F4>; polling-delay = <0x3E8>; thermal-sensors = <0x73 0x2>; sustainable-power = <0x39F>; trips { phandle = <0xD4>; trip-point@0 { temperature = <0x11170>; type = "passive"; hysteresis = <0x0>; phandle = <0xD5>; }; trip-point@1 { temperature = <0x15F90>; type = "passive"; hysteresis = <0x0>; phandle = <0x74>; }; cpu_crit@0 { temperature = <0x1C138>; type = "critical"; hysteresis = <0x0>; phandle = <0xD6>; }; }; cooling-maps { map0 { trip = <0x74>; cooling-device = <0x75 0xFFFFFFFF 0xFFFFFFFF>; contribution = <0x400>; }; map1 { trip = <0x74>; cooling-device = <0x76 0xFFFFFFFF 0xFFFFFFFF>; contribution = <0x400>; }; }; }; ddr_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0x73 0x3>; }; gpu_thermal_zone { polling-delay-passive = <0x1F4>; polling-delay = <0x3E8>; thermal-sensors = <0x73 0x0>; sustainable-power = <0x44C>; }; ve_thermal_zone { polling-delay-passive = <0x0>; polling-delay = <0x0>; thermal-sensors = <0x73 0x1>; }; }; And for bluetooth in the same dts file i can see this. bt { compatible = "allwinner,sunxi-bt"; clocks = <0xE 0x4>; clock-names = "osc32k-out"; bt_power; bt_rst_n = <0x23 0x6 0x13 0x1>; phandle = <0xCF>; }; /******/ addr_mgt { compatible = "allwinner,sunxi-addr_mgt"; status = "okay"; type_addr_wifi = <0x0>; type_addr_bt = <0x0>; type_addr_eth = <0x0>; phandle = <0xD0>; }; btlpm { compatible = "allwinner,sunxi-btlpm"; status = "okay"; uart_index = <0x1>; bt_wake = <0x23 0x6 0x11 0x0>; bt_hostwake = <0x23 0x6 0x10 0x0>; wakeup-source; phandle = <0xD1>; }; Edited October 10, 2024 by MMorales 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 (edited) @MMorales With my Compiled version of @Nick A github trunk with 6.7.12 kernel. I don't have problems except (Bluetooth). WiFi works and connects to my router. CPU Temp Sensor Works. OpenVfd is working. (with downloaded headers for 6.7.12) Sound is working LAN is Working. HDMI is working. Video (MPV with hardware Acceleration) seems to work Remote IR is working (with above .toml file and ir-keytables) Finally Only the BlueTooth is not Working. Edited October 10, 2024 by rafman 0 Quote
MMorales Posted October 10, 2024 Posted October 10, 2024 @rafman do you know how to get the cpu temp by commandline in your system ? Im not using graphical interface cos im want it as server. 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 4 minutes ago, MMorales said: do you know how to get the cpu temp by commandline in your system ? Im not using graphical interface cos im want it as server. use: cat /sys/class/hwmon/hwmon0/temp1_input |awk '{printf "%.2s", $1}' 0 Quote
MMorales Posted October 10, 2024 Posted October 10, 2024 @rafman not working in my 6.9.12-edge-sunxi64. /sys/class/hwmon is an empy folder. 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 (edited) 25 minutes ago, MMorales said: not working in my 6.9.12-edge-sunxi64. /sys/class/hwmon is an empy folder. This probably is because the kernel and / or the u-boot patches. You can try my compiled image (burn it to a seperate SD card) and test it (I Tested on Transpeed 8k 4/64) You can Download it Here : https://easyupload.io/j19vgs Don't try to switch kernel because it will break, just download the headers from above link. and install it with sudo dpkg -i <deb_file > and then you can compile openvfd. Edited October 10, 2024 by rafman 0 Quote
MMorales Posted October 10, 2024 Posted October 10, 2024 very thanks @rafman but im not going to move cos its all configured (a lot of work). Dont worth a full instalation for getting only the thermal. by the way i have tested the 6.10 @Nick A and the thermal sensors neither works. 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 4 minutes ago, MMorales said: i have tested the 6.10 @Nick A and the thermal sensors neither works. I did not test with other kernel previous to 6.7.12 however 6.7.12 seems to be stable for me. But I had problems switching to newer kernels like 6.10.9. (no boot at all) i will make further checks with 6.7.12. 0 Quote
MMorales Posted October 10, 2024 Posted October 10, 2024 @rafman 6.7.12 was perfect for me and i was everything working but from emmc : each time i do a "halt" or unplug the cable, after that the system dont boot correctly anymore. So i switched to 6.9. 0 Quote
rafman Posted October 10, 2024 Posted October 10, 2024 6 minutes ago, MMorales said: 6.7.12 was perfect for me and i was everything working but from emmc : each time i do a "halt" or unplug the cable, after that the system dont boot correctly anymore. So i switched to 6.9. I already do this right now, and i have also installed Armbian on eMMC. i give the command sudo halt the system halts, and after boots normally (when i unplug and re-plug the power cable) on sudo reboot no problems. FYI: when my system Was on SD Card i remember (but not always) sometimes i had problem to boot when the keyboard and mouse was connected to tv-box but when i removed both the usb cables the problem was solved. 0 Quote
Nick A Posted October 10, 2024 Posted October 10, 2024 (edited) I guess the thermal patches where mainlined for kernel 6.10. Maybe it still needs the 6.9 patch? Or something is missing in the kernel config? Kernel 6.7. https://github.com/NickAlilovic/build/blob/main/patch/kernel/archive/sunxi-6.7/patches.armbian/arm64-dts-allwinner-h616-Add-thermal-sensor-and-thermal-zones.patch https://github.com/NickAlilovic/build/blob/main/patch/kernel/archive/sunxi-6.7/patches.armbian/arm64-dts-allwinner-h616-Fix-thermal-zones-missing-trips.patch Kernel 6.9 (Missing Trips and most of the DT thermal settings were added to 6.9 mainline kernel.) https://github.com/NickAlilovic/build/blob/v20240909/patch/kernel/archive/sunxi-6.9/patches.armbian/arm64-dts-allwinner-h616-Add-thermal-sensor-and-thermal-zones.patch Bluetooth still has issues. The bluetooth interface randomly changes from hci0 to hci1. At first there was a problem with the Internal 32Khz OSC Clock. By enabling the Internal OSC Clock Auto Calibration Register we got a 32Khz needed to detect Bluetooth. But there's something missing. Right now it works when it feels like it. Usually when I enable Bluetooth using Android then reboot to Armbian It works. Can someone with a Transpeed 8k618-t measure the 32KHz clock with a Oscilloscope? The 32Khz fanout is routed to PG10 pin on the SOC and connected to the LPO pin of the WiFi/BT chip. Depending on your wifi chip you might be missing the BT firmware. I have a 4335 chip so I use BCM4335A0.hcd. You can find the original firmware on your android partition if you still have it or search around online. Edited October 10, 2024 by Nick A 0 Quote
firepower Posted October 10, 2024 Posted October 10, 2024 What is the wifi chip used in the Vontar H618 ? Its on sale again and I can buy for good price. 0 Quote
MMorales Posted October 11, 2024 Posted October 11, 2024 (edited) Quote Kernel 6.9 (Missing Trips and most of the DT thermal settings were added to 6.9 mainline kernel.) @Nick A I have 6.9.12 there are no sensors working. And i tried to compile a 6.10 with this patch: https://github.com/NickAlilovic/build/blob/v20240909/patch/kernel/archive/sunxi-6.9/patches.armbian/arm64-dts-allwinner-h616-Add-thermal-sensor-and-thermal-zones.patch and gave me these errors. [🔨] │ Patch │ Patching output │ Rejects │ [🔨] ├──────────────────────┼──────────────────────────────────────────┼────────────────────────────────────────────────────┤ [🔨] │ arm64-dts-allwinner │ patching file │ --- arch/arm64/boot/dts/allwinner/sun50i-h616.dtsi │ [🔨] │ -h616-Add-thermal-se │ "arch/arm64/boot/dts/allwinner/sun50i-h6 │ +++ arch/arm64/boot/dts/allwinner/sun50i-h616.dtsi │ [🔨] │ nsor-and-thermal-zon │ 16.dtsi" │ @@ -26,6 +26,8 @@ cpu0: cpu@0 { │ [🔨] │ es │ Hunk #1 FAILED at 26. │ reg = <0>; │ [🔨] │ │ Hunk #2 FAILED at 34. │ enable-method = "psci"; │ [🔨] │ │ Hunk #3 FAILED at 42. │ clocks = <&ccu CLK_CPUX>; │ [🔨] │ │ Hunk #4 FAILED at 50. │ + clock-latency-ns = <244144>; /* 8 32k │ [🔨] │ │ Hunk #5 succeeded at 1314 (offset 392 │ periods */ │ [🔨] │ │ lines). │ + #cooling-cells = <2>; │ [🔨] │ │ Hunk #6 succeeded at 1335 (offset 392 │ }; │ [🔨] │ │ lines). │ │ [🔨] │ │ 4 out of 6 hunks FAILED -- saving │ cpu1: cpu@1 { │ [🔨] │ │ rejects to file "/tmp/tmpkj1juhfw" │ @@ -34,6 +36,8 @@ cpu1: cpu@1 { │ This is my first try to compile armbian so sorry for my errors. Could be posible compile the 6.9.12 with the correct patch to get working the thermal sensor and then copy the compiled module to an existing working emmc with the same kernel ? Edited October 11, 2024 by MMorales 0 Quote
MMorales Posted October 11, 2024 Posted October 11, 2024 (edited) Quote Can someone with a Transpeed 8k618-t measure the 32KHz clock with a Oscilloscope? The 32Khz fanout is routed to PG10 pin on the SOC and connected to the LPO pin of the WiFi/BT chip. @Nick A u mean this one ? its written 37.400 @firepower you can see here the wifi chip too EDIT: I saw the other xtal wich is half covered by the disipator. u mean this ? Edited October 11, 2024 by MMorales 0 Quote
