firepower Posted 6 hours ago Posted 6 hours ago There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them. 0 Quote
svyatoslav Posted 6 hours ago Posted 6 hours ago E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
svyatoslav Posted 6 hours ago Posted 6 hours ago firepower https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Vontar-h618_bookworm_edge_6.12.11_xfce_desktop.img.xz https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img.xz this? 0 Quote
Nick A Posted 4 hours ago Posted 4 hours ago (edited) @svyatoslav there’s android firmware but the Linux driver is old. Your dmesg doesn’t show any wifi info because there’s no driver. Unless you know how modify kernel drivers I would forget about it and use a usb wifi adapter. Edited 4 hours ago by Nick A 0 Quote
svyatoslav Posted 4 hours ago Posted 4 hours ago Unfortunately, the USB adapter was not detected either, there is still no sound. this image used: Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_xfce_desktop.img 0 Quote
svyatoslav Posted 4 hours ago Posted 4 hours ago 2 часа назад, firepower сказал: There was ssv6x5x android drivers in the tanix and vontar firmware i upload. You could try them Please give me a link to your image. I'm trying to make a micro computer for my child, so I'm puzzled by remaking the console, if he wants to watch cartoons he'll figure it out. This is useful, the kid is 6 years old and he only watches cartoons, both on TV and on the phone. 0 Quote
979101h Posted 3 hours ago Posted 3 hours ago I have a box identical to the X98H. After installing the Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img.xz image compiled by Nike, the Ethernet port is not working. Here's the content returned by the dmesg command 0 Quote
kvvvp Posted 2 hours ago Posted 2 hours ago 1 час назад, svyatoslav сказал: the USB adapter was not detected either, t There is a stripped-down firmware in the Armbian images. Update it using armbian-config. Maybe the USB-WI-FI will work. But keep in mind that the updated firmware will take about 1 GB of memory. 0 Quote
svyatoslav Posted 2 hours ago Posted 2 hours ago (edited) Они видны, но не работают. root@x98h:~# lsusb Шина 005 Устройство 002: ID 8301:0089 Беспроводная клавиатура Hapurs HPBT05R 2.4 G Mini Wireless Touchpad Шина 005 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 003 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 004 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 002 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 006 Устройство 001: ID 1d6b:0001 Linux Foundation 1.1 корневой концентратор Шина 001 Устройство 003: ID 148f:7601 Ralink Technology, Corp. Беспроводной адаптер MT7601U Шина 001 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Шина 007 Устройство 001: ID 1d6b:0002 Linux Foundation 2.0 корневой концентратор Лучше всего работает: Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop., но нет Wi-Fi и звука. dmesg.txt Edited 1 hour ago by svyatoslav 0 Quote
svyatoslav Posted 1 hour ago Posted 1 hour ago (edited) 16.04.2025 в 05:10, firepower сказал: Вот полная прошивка brcm wifi BT. Я обнаружил, что она может быть полезна для других устройств wifi BT. no access all links to your images are not available Edited 57 minutes ago by svyatoslav 0 Quote
svyatoslav Posted 11 minutes ago Posted 11 minutes ago doesn't want to get ready, tell me where to go? E: Unable to correct problems, you have held broken packages. [💥] error! [ Failed to install host packages; make sure you have a sane sources.list. ] [💥] Exiting with error 43 [ at /home/toor/build/lib/functions/logging/traps.sh:1 exit_with_error() --> lib/functions/logging/traps.sh:1 install_host_side_packages() --> lib/functions/host/host-utils.sh:81 install_host_dependencies() --> lib/functions/host/prepare-host.sh:304 prepare_host_noninteractive() --> lib/functions/host/prepare-host.sh:92 do_with_logging() --> lib/functions/logging/section-logging.sh:81 prepare_host() --> lib/functions/host/prepare-host.sh:17 prepare_host_init() --> lib/functions/main/start-end.sh:64 main_default_start_build() --> lib/functions/main/start-end.sh:17 do_with_default_build() --> lib/functions/main/default-build.sh:41 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] 0 Quote
