[Armbian build PR] - rtl8811cu, rtl8723cs: Fix module build failure on 6.5 kernel
Description
Fixed driver compilation for RTL8811CU and RTL8723CS on 6.5 kernel
How Has This Been Tested?
  • [X] Tested creating build for nanopiduo2 with 6.1, 6.4 and 6.5 kernels to make sure build succeeds
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
