Posted (edited)
I can't tell you which u-boot image to use until I get more information. u-boot is in the images you write to your sdcard.
If you want try all these images.
https://github.com/NickAlilovic/build/releases/tag/20250306
The best way to know if it's booting is to install a usb serial ttl device to your uart. Then use a terminal software to view u-boot/kernel messages.
sudo gtkterm -p /dev/ttyUSB0 -s 115200
Edited by Nick A
@Nick A I tested the image you sent, but it remains a black screen. Does this black screen mean that the TV box is trying to read it, but is unable to do so, or is it something else?
Posted (edited)
Sorry but I can't help any further without this device installed.. we are working blind right now.
If it still boots Android then the box should be okay. There's always a risk when modifying a tv box. I haven't broken one yet.
Edited by Nick A
@Nick AAfter a lot of searching I found an ISO that my TV box "accepts", by reading the card with it, but every time I try to install mini arch, instead of installing in the flash memory, it installs via the SD card and I want it to be in the TV box's memory, how can I solve this?
Posted (edited)
I just saw your wifi chip in the picture. Unfortunately, this chip only has drivers for older kernel versions.
You’ll need to use a usb wifi device or Ethernet.
Edited by Nick A
The driver is old. It needs to be updated to work on the newer kernels. You can try compiling it and see if it works. I don’t have a box with this wifi chip so I can’t help you.
Here's the steps to create a secure boot image
git clone https://github.com/NickAlilovic/build.git --branch v20250306
cd build
pico patch/u-boot/u-boot-h616/153-add-tanix_tx6s_axp313_defconfig.patch
You need to add this line to the bottom. "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and change "@@ -0,0 +1,37 @@" to @@ -0,0 +1,38 @@.
diff --speed-large-files --no-dereference --minimal -Naur u-boot-sunxi-647b392bf20614006917d5fcd3390347a668eee5/configs/tanix_tx6s_axp313_defconfig u-boot-sunxi-647b392bf20614006917d5fcd3390347a668eee5/configs/tanix_tx6s_axp313_defconfig
--- u-boot-sunxi-647b392bf20614006917d5fcd3390347a668eee5/configs/tanix_tx6s_axp313_defconfig	1970-01-01 01:00:00.000000000 +0100
+++ u-boot-sunxi-647b392bf20614006917d5fcd3390347a668eee5/configs/tanix_tx6s_axp313_defconfig	2023-04-08 11:53:13.408413187 +0200
@@ -0,0 +1,38 @@
+CONFIG_ARM=y
+CONFIG_ARCH_SUNXI=y
+CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h616-tanix-tx6s-axp313"
+CONFIG_SPL=y
+CONFIG_SUNXI_DRAM_H616_DDR3_1333=y
+CONFIG_DRAM_CLK=648
+CONFIG_DRAM_ODT_EN=y
+CONFIG_DRAM_SUN50I_H616_UNKNOWN_FEATURE=y
+CONFIG_DRAM_SUN50I_H616_BIT_DELAY_COMPENSATION=y
+CONFIG_DRAM_SUN50I_H616_READ_CALIBRATION=y
+CONFIG_DRAM_SUN50I_H616_DX_ODT=0x03030303
+CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0e0e0e0e
+CONFIG_DRAM_SUN50I_H616_CA_DRI=0x00001c12
+CONFIG_DRAM_SUN50I_H616_ODT_EN=0x00000001
+CONFIG_DRAM_SUN50I_H616_TPR0=0xc0000c05
+CONFIG_DRAM_SUN50I_H616_TPR2=0x00000000
+CONFIG_DRAM_SUN50I_H616_TPR10=0x2f0007
+CONFIG_DRAM_SUN50I_H616_TPR11=0xffffdddd
+CONFIG_DRAM_SUN50I_H616_TPR12=0xfedf7557
+CONFIG_MACH_SUN50I_H616=y
+CONFIG_R_I2C_ENABLE=y
+CONFIG_SPL_I2C=y
+CONFIG_SPL_I2C_SUPPORT=y
+CONFIG_SPL_SYS_I2C_LEGACY=y
+CONFIG_SYS_I2C_MVTWSI=y
+CONFIG_SYS_I2C_SLAVE=0x7f
+CONFIG_SYS_I2C_SPEED=100000
+CONFIG_PHY_REALTEK=y
+CONFIG_SUN8I_EMAC=y
+CONFIG_I2C3_ENABLE=y
+CONFIG_AXP313_POWER=y
+CONFIG_USB_EHCI_HCD=y
+CONFIG_USB_OHCI_HCD=y
+CONFIG_USB_MUSB_GADGET=y
+CONFIG_SUPPORT_EMMC_BOOT=y
+CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x40
+CONFIG_MMC_SUNXI_SLOT_EXTRA=2
pico patch/u-boot/u-boot-h616/secure-boot.patch
create the secure boot patch.
diff --git a/root_key.pem b/root_key.pem
new file mode 100644
index 0000000000..892a10ef90
--- /dev/null
+++ b/root_key.pem
@@ -0,0 +1,28 @@
+-----BEGIN PRIVATE KEY-----
+MIIEvgIBADANBgkqhkiG9w0BAQEFAASCBKgwggSkAgEAAoIBAQCWZ7G39E+RCi+9
+B48yiD4GxnfqNzvlXOxAd+GHQuKbgynXZd5pIuNHt3ewhZTHZkdHxuO9liqX9MmU
+8OhiG+Skww2LzHPPi/eLeN4vCt/waXkjFrkblkhNzB3c6MejKdiz9sfw8oeOFX1S
+teP/MJBoRaj6Hexj5g/oCspU+KFfv0cOBcWuq4vZwPJ6+U44IBi7EGleShGHNhBI
+xQEyvNaDLWoDCPGLrjRM0DrIbUpzEntk9KJ0z+3Th8O/FtvlW21atolIVr5F96Pw
+EEv3CDUHrY+IvK0z+IwNhnYo99kMPi5djB6vviz4In530JQ+OdPxhi4cQY3Yw9wx
+Sm8EFaRRAgMBAAECggEAEaEcZ+k7VU8aGuBStNPa31zui9XHD8KlT4YtuXbJzHwi
+kKSYXf7woISdAyQZNQkkREHICn4aRn7zDOHy/yLxWS2ivhbsITDxBlhXxLBT4OBg
+ClCcyGLEXVgWTQE8+z9Jrwh3VaL76BfVPXdj/tKwroQxwwV0Yp5CEYsIPc75zVjW
+Y2tppJL9XlTfKXTSo7FAxJmjkTC8QGPSHgMglR5FOfZ/D3Nj4KV4LV1gHCkICKUy
+c2jklHISy8S6/pvgpWb50TKArEhbN6uAKQBNb74ZsChKJ9h9aof/vjH/8Ab1rwUJ
+g91lpkR3mEefTjJTW1JOuoT49Y3lfWmkRVh75GiCsQKBgQDUo3uMcy9VdbbmY9Gt
+2JuhbSvwR/dOHZJoXvtlNYVJ+1JvavExBy2u31cYsK/2SH/Upc8AXS6H02dXbnC3
+wjlUFi21Xi7/PCQM8TUz05km3+9qOkDYw53EBBBnCdjawBpDgcUSkoZGU+ltBzcR
+sj0nsmI29DjwfYHXhofnlfI52QKBgQC1E2Q0hGfk3YUtfzTjDJCfd3gs6QYGQGeT
+49jvnsbYsnz9vsK4Ao2skN8nBhSefDJR8h2X+7tRXEefQB2Hy/+9qoiuoVzPJGWD
+IiHjeVJDoEqA2Q483UhZ+OPjUGFDTI7O/j1A1HkEBKswdJpKlGVygdoXYaieUAfz
+Sb+dCYf7OQKBgQCWkE/aSnE4vQpOJl4BEABbFFdpYzvcpxnVJ3Qw3O3NTdS4Keww
+wBl72o7sX6eo5vsE0oc5hcF90ZY6FWxg4XkAblfdNZxng+ku9NisIuct3KDFAgyK
+sDCU7B/FJfbUJfQy2r91gCTtxVripZo7wI6G/kuHB/UNbIE04AB5XfZPOQKBgAGw
+K5f9wAY3Nn2lGPYg8Nw7vegVSBQY155eWnBpd4sfpuCqvZ//jhiUxS/U865ClCmF
+a1c2ZpmslZJbg6r3cOvwwhN2t6nKuhON5uj7AZRV0zv+Sg6xNXJ5So6c+jspZI9z
+eVi4YmRyMrJh8+pMFeIKaeEb7PmE334aKuoo45apAoGBAKNp7ssXgU4Ma7cUr7+L
+TKGBNVsMZyM3T2qsXJjFY1f90+lwp7TlNQGVMPOSOHxyINWkuLNgAgetlhavnc0S
+0l+SbSaO6SfnHfQWBFPEJfol8V/Xa4rcVP7fGxQn4phYnk14N09xKIQa24Mi2Xa5
+9G0C2VOB8Yz6OWcQZELs0uFp
+-----END PRIVATE KEY-----
2.34.1
./compile.sh
choose "Do not change kernel configuration"
choose "Show CSC/WIP/EOS/TVB"
choose "I understand and agree"
choose "tanix-tx6s-axp313"
choose "edge"
rest is up to you.
Your image should be in output/images directory.
@Nick A It started, but it stopped right at the beginning. In fact, well before than the other image secure boot for H618.
U-Boot SPL 2025.01-armbian-2025.01-S6d41-P13d0-H8869-Vfdd1-Bb703-R448a-dirty (Apr 25 2025 - 18:09:15 -0300)
DRAM:testing 32-bit width, rank = 2
read calibration failed!
testing 32-bit width, rank = 1
DRAM:Store cfg
DRAM:1st writing pattern
DRAM:detecting column address bits
detected 11 columns
DRAM:restore cfg
DRAM:reconfigure for all active rows
DRAM:store cfg
DRAM:2nd writing pattern
DRAM:detecting row address bits
detected 15 rows
DRAM:restoring cfg
DRAM:end of auto detect dram size
MBUS port 0 cfg0 0100000d cfg1 00640080
MBUS port 1 cfg0 06000009 cfg1 01000578
MBUS port 2 cfg0 0200000d cfg1 00600100
MBUS port 3 cfg0 01000009 cfg1 00500064
MBUS port 4 cfg0 20000209 cfg1 1388157c
MBUS port 5 cfg0 00640209 cfg1 00200040
MBUS port 6 cfg0 00640209 cfg1 00200040
MBUS port 8 cfg0 01000009 cfg1 00400080
MBUS port 11 cfg0 01000009 cfg1 00640080
MBUS port 14 cfg0 04000009 cfg1 00400100
MBUS port 16 cfg0 2000060d cfg1 09600af0
MBUS port 21 cfg0 0800060d cfg1 02000300
MBUS port 22 cfg0 01000009 cfg1 00640080
MBUS port 25 cfg0 0064000f cfg1 00200040
MBUS port 26 cfg0 20000209 cfg1 1388157c
MBUS port 37 cfg0 01000009 cfg1 00400080
MBUS port 38 cfg0 00640209 cfg1 00200040
MBUS port 39 cfg0 20000209 cfg1 1388157c
MBUS port 40 cfg0 00640209 cfg1 00200040
 2048 MiB
Trying to boot from MMC1
Guys, does anyone know how to enable the TV Box's wifi with the ik316 process? I downloaded armbian, the only thing missing is wifi. Data transmission works with a network cable, only the wifi is having problems. The iso I downloaded was Armbian-unofficial_25.05.0-trunk_X96q-lpddr3_bookworm_edge_6.12.11_xfce_desktop.img.xz
