Aleqssandro Farias Posted May 19 Posted May 19 (edited) Hi @Nick A, good afternoon! Yes, I tested them — I tried all three ISOs you shared. I'm sending you the UART logs from two of them: the one you specifically asked me to test and the MiniArch one. The one you asked me to try throws a DRAM error, while the MiniArch image actually boots — maybe because it’s configured for eMCP. log_miniarch.txt log_armbian_unofficial.txt Edited May 19 by Aleqssandro Farias 0 Quote
Nick A Posted May 20 Posted May 20 @Aleqssandro Farias your miniarch image says it’s using Tanix TX6s (axp313). Try the armbian version. https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_Tanix-tx6s-axp313_bookworm_edge_6.12.11.img.xz 0 Quote
Aleqssandro Farias Posted May 20 Posted May 20 Hi @Nick A, This ISO you sent has the same UART log error as the previous one. Here's the log: " U-Boot SPL 2025.01-armbian-2025.01-S6d41-P7151-H8869-V98f7-Bb703-R448a-dirty (Apr 02 2025 - 21:19:05 -0400) DRAM: testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 read calibration failed! testing 16-bit width, rank = 2 read calibration failed! testing 16-bit width, rank = 1 read calibration failed! This DRAM setup is currently not supported. resetting ... " Right now, the only image that boots properly is the MiniArch one. 0 Quote
Aleqssandro Farias Posted May 20 Posted May 20 (edited) Good afternoon @Nick A I managed to make some progress with the ISO you envy. I extracted the DTB used in MiniArch (which worked on the IK316 TV box) and replaced the DTB in its ISO. However, I noticed that the same error persisted. So, I decided to change the bootloader using the following commands: Extracted the working bootloader: $ dd if=MiniArch-20240715-6.14.0-board-h616.tanix_tx6s_axp313-SD-Image.img of=u-boot-sunxi-with-spl.bin bs=1024 skip=8 count=1016 So I injected it into the ISO that you envied me: $ dd if=u-boot-sunxi-with-spl.bin of=Armbian-unofficial_25.05.0-trunk_Tanix-tx6s-axp313_bookworm_edge_6.12.11.img bs=1024 seek=8 conv=notrunc After that, I got a new log and the TV Box booted, but I believe Armbian didn't start properly — it seems to take me to the U-Boot console. Here's the full log: " U-Boot SPL 2025.01 (24 de março de 2025 - 21:02:39 +0100) DRAM: 1024 MiB Tentando inicializar a partir do MMC1 AVISO: BL31: v2.10.0 (depuração):v14.0.0-98-gde86a8ab6 AVISO: BL31: Compilado: 01:02:27, 19 de março de 2025 AVISO: BL31: SoC Allwinner H61 detectado (1823) AVISO: BL31: DTB U-Boot encontrado em 0x4a0b0f80, modelo: Tanix TX6s (axp313) INFO: Driver ARM GICv2 inicializado INFO: Configurando o driver SPC INFO: PMIC: Sondando AXP305 sem RSB ERRO: RSB: tempo de execução definido endereço: 0x10003 INFO: Não foi possível inicializar RSB: -65539 INFO: BL31: Configuração da plataforma concluída INFO: BL31: Inicializando serviços de tempo de execução INFO: BL31: cortex_a53: Solução alternativa da CPU para a errata 855873 foi aplicada INFO: BL31: cortex_a53: solução alternativa da CPU para a errata 1530924 foi aplicada INFO: PSCI: Suspender não está disponível INFO: BL31: Preparando para saída EL3 para o mundo normal INFO: Endereço do ponto de entrada = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Árvore de dispositivos alterados. U-Boot 2025.01 (24 de março de 2025 - 21:02:39 +0100) Tecnologia Allwinner CPU: Allwinner H616 (SUN50I) Modelo: Tanix TX6s (axp313) DRAM: 1 GiB Núcleo: 58 dispositivos, 20 uclasses, devicetree: separado WDT: Não iniciando watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 3, mmc@4022000: 1 Carregando ambiente do FAT... Não é possível usar mmc 0:1... Entrada: serial@5000000 Saída: serial@5000000 Erro: serial@5000000 Nenhum dispositivo USB encontrado Rede: Não foi possível obter PHY para ethernet@5030000: endereço 16 Nenhuma ethernet encontrada. iniciando USB... Nenhum driver USB encontrado Pressione qualquer tecla para parar a inicialização automática: 0 alternativa para partições #0, OK mmc0 é o dispositivo atual Verificando mmc 0:1... Encontrado /boot/extlinux/extlinux.conf Recuperando arquivo: /boot/extlinux/extlinux.conf 1: MiniArch Recuperando arquivo: /boot/Image Recuperando arquivo: /boot/initrd.img append: root=/dev/mmcblk0p1 rootwait console=ttyS0,115200 panic=10 Recuperando arquivo: /boot/dtbs/allwinner/sun50i-h616-tanix-tx6s-axp313. dtb Movendo imagem de 0x40080000 para 0x40200000, end=0x420b0000 ## Blob da árvore de dispositivos achatada em 4fa00000 Inicializando usando o blob fdt em 0x4fa00000 FDT de trabalho definido como 4fa00000 Carregando Ramdisk para 49853000, fim 49fffc5e ... OK Carregando Árvore de Dispositivos para 0000000049848000, fim 00000000498524af ... OK FDT de trabalho definido como 49848000 Iniciando o kernel... :: Executando o gancho inicial [udev] Iniciando o systemd-udevd versão 253-1-arch :: Executando o gancho [udev] :: Disparando uevents... :: Executando o gancho [mapa de teclas] :: Carregando o mapa de teclas...kbd_mode: KDSKBMODE: ioctl inadequado para o dispositivo completo. :: montando '/dev/mmcblk0p1' na raiz real : executando o gancho de limpeza [udev] ERRO: Dispositivo raiz montado com sucesso, mas /sbin/init não existe. Saindo do controle, você está por conta própria. Boa sorte. sh: não é possível acessar tty; controle de tarefas desativado [rootfs]# " It looks like the root device was mounted correctly, but it couldn't find /sbin/init, so the system couldn't continue booting. Let me know if you have any suggestions or if you want me to try something else. Edited May 20 by Aleqssandro Farias 0 Quote
Nick A Posted May 20 Posted May 20 (edited) @Aleqssandro Farias which miniarch image are you using? Because I’m using miniarch patches so the dts should be the same. Edited May 20 by Nick A 0 Quote
Aleqssandro Farias Posted May 20 Posted May 20 @Nick A I’m using the MiniArch image that was shared here on the forum. From it, I extracted the DTBs, Image, and other boot files, and replaced them in the Armbian image. I also took the bootloader from the MiniArch image and replaced the one in Armbian. With that, I managed to boot into Armbian, but unfortunately, no network adapters were detected. 0 Quote
Alexandre Nery Posted July 11 Posted July 11 Hello, would you be able to share the ISO you used along with the modified DTBs? @Aleqssandro Farias 0 Quote
Jeeva Kandasamy Posted Friday at 01:01 PM Posted Friday at 01:01 PM Hi @Nick A thanks for the build details. It is working perfectly in my hardware: IK316Q-EMCP_V4.1 (IK3166-H, AXP313A, TYDOGH221664RA [1GB+8GB]) Current image: https://github.com/NickAlilovic/build/releases/download/20250306/Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_server.img.xz However when I do apt upgrade I get the following error, Err:7 https://mirror.albony.in/armbian bookworm Release Redirection from https to 'http://mirror.hyd.albony.in/armbian/dists/bookworm/Release' is forbidden [IP: 82.180.145.196 443] I am using this device as headless server for IoT with internet, So I would like to keep updated kernel and packages all the time. Can you please guide me how to achieve this? 0 Quote
Nick A Posted Friday at 03:26 PM Posted Friday at 03:26 PM (edited) @Jeeva Kandasamy I would freeze your kernel updates using armbian-config. I’m using a custom kernel so it will break your system. I made google search and found this. https://github.com/MichaIng/DietPi/issues/4600 Edited Saturday at 03:57 AM by Nick A 0 Quote
Jeeva Kandasamy Posted Saturday at 05:46 AM Posted Saturday at 05:46 AM Thanks @Nick A for the details and link shared ! If I understand correctly, I can build kernel only locally and freeze kernel update. other packages can be downloaded from public repository Is that correct? 0 Quote
Jeeva Kandasamy Posted 3 hours ago Posted 3 hours ago (edited) Hi @Nick A I tried build your fork repository and facing the following error, Can you please help me to fix this error? Source code: https://github.com/NickAlilovic/build/ $ git remote -v origin git@github.com:NickAlilovic/build.git (fetch) origin git@github.com:NickAlilovic/build.git (push) $ git branch main * v20250306 Build command: ./compile.sh build BOARD=x96q-lpddr3-v1-3 BRANCH=edge BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=yes RELEASE=trixie Error: [🐳|🌱] git: Fetch from remote completed, rev-parsing... [ 'debootstrap-debian-devel' 'master' 'FETCH_HEAD' ] [🐳|🌱] Debootstrap version [ '1.0.142' for /armbian/cache/sources/debootstrap-debian-devel/debootstrap ] [🐳|🌱] Installing base system with 5 packages [ Stage 1/2 ] [🐳|🔨] I: Retrieving InRelease [🐳|🔨] I: Checking Release signature [🐳|🔨] E: Release signed by unknown key (key id 762F67A0B2C39DE4) [🐳|🔨] The specified keyring /usr/share/keyrings/debian-archive-keyring.gpg may be incorrect or out of date. [🐳|🔨] You can find the latest Debian release key at https://ftp-master.debian.org/keys.html [🐳|💥] error! [ Debootstrap first stage failed /armbian/cache/sources/debootstrap-debian-devel/debootstrap trixie yes ] [🐳|💥] Cleaning up [ please wait for cleanups to finish ] Edited 3 hours ago by Jeeva Kandasamy 0 Quote
