kvic80 Posted August 30, 2023 Posted August 30, 2023 Hi Forum members, I have a Beelink GT1 Ultimate tvbox (RTL8211f/LTM8830) which came to me with Coreelec, so not the stock Android firmware. I had to install the Android firmware (found somewhere on internet, not from Beelink) in order to be able to run Armbian (off sd card) and no matter which .dtb I try, there is no LAN in Armbian (no phy), but also it doesn't work in Android. Am I right in that I cannot make it work in Armbian if it doesn't work in Android? Case 1: Eth port/rtl8211f chip is damaged Case 2: the Android firmware image does not fit my tv box Is there a chance that case 2 is the situation so if I find an Android image with working LAN then I'm done? By the way now when I start the box with sd card (Armbian) in it, the very first lines that appear after the logo are: Net: Could not get PHY for mdio@2009087f: addr 0 No ethernet found. I also have another GT1, non-ultimate with the same RTL8211f chip and it works great with Armbian. 0 Quote
