[Armbian build PR] - [WIP]rockchip64: bump rockchip64-edge kernel to 6.5
Description
Patches are updated and build is successful. I haven't tested the kernel yet. Here are patch fixes: 1, add-rockchip-iep-driver.patch: rk3288.dtsi is moved to arch/arm/boot/dts/rockchip/rk3288.dtsi 2, general-possibility-of-disabling-rk808-rtc.patch: drivers/mfd/rk808.c is moved to drivers/mfd/rk8xx-core.c 3, rk356x-rga.patch: removed becaused of upstream merged 4, board-rockpis-0001-arm64-dts.patch: fixed due to upstream change 5, board-nanopi-r2c-plus.patch: new added patch fixing missing &vcc_io_33
How Has This Been Tested?
  • [x] Patches are all applied
  • [x] Kernel build is successfull
Checklist:
  • [ ] I have made corresponding changes to the documentation
View the full article
