RSS Bot Posted September 4, 2023 Posted September 4, 2023 Description A change to ledtrig_netdev driver causes the boot to fail on Orangepi-r1plus-lts and possibly other boards. The board boots and LED netdev trigger works if service is modified to occur later in the boot sequence by using After=timers.target in armbian-led-state.service. Jira reference number AR-1875 Issue discussion rockchip64: bump rockchip64-edge kernel to 6.5#5657 How Has This Been Tested? Tested on current and 6.5y Rockchip64 and other (H5). The following configurations were tested for boot, reboot and shutdown then boot and that LED's light when network is connected and LED's flicker on network activity: [x] Orangepi R1 Plus LTS with Kernel 6.5y with ledtrig_netdev configured for two ethernet ports and two LED's. [x] Orangepi R1 Plus LTS with Kernel 6.1y with ledtrig_netdev configured for two ethernet ports and two LED's. [x] Orangepi Zero Plus with Kernel 6.5y with ledtrig_netdev configured for one ethernet ports and one LED. Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
