RSS Bot Posted September 4, 2023 Posted September 4, 2023 Bumps actions/checkout from 3 to 4. Release notes Sourced from actions/checkout's releases. v4.0.0 What's Changed Update default runtime to node20 by @takost in actions/checkout#1436 Support fetching without the --progress option by @simonbaird in actions/checkout#1067 Release 4.0.0 by @takost in actions/checkout#1447 New Contributors @takost made their first contribution in actions/checkout#1436 @simonbaird made their first contribution in actions/checkout#1067 Full Changelog: https://github.com/actions/checkout/compare/v3...v4.0.0 v3.6.0 What's Changed Mark test scripts with Bash'isms to be run via Bash by @dscho in actions/checkout#1377 Add option to fetch tags even if fetch-depth > 0 by @RobertWieczoreck in actions/checkout#579 Release 3.6.0 by @luketomlinson in actions/checkout#1437 New Contributors @RobertWieczoreck made their first contribution in actions/checkout#579 @luketomlinson made their first contribution in actions/checkout#1437 Full Changelog: https://github.com/actions/checkout/compare/v3.5.3...v3.6.0 v3.5.3 What's Changed Fix: Checkout Issue in self hosted runner due to faulty submodule check-ins by @megamanics in actions/checkout#1196 Fix typos found by codespell by @DimitriPapadopoulos in actions/checkout#1287 Add support for sparse checkouts by @dscho and @dfdez in actions/checkout#1369 Release v3.5.3 by @TingluoHuang in actions/checkout#1376 New Contributors @megamanics made their first contribution in actions/checkout#1196 @DimitriPapadopoulos made their first contribution in actions/checkout#1287 @dfdez made their first contribution in actions/checkout#1369 Full Changelog: https://github.com/actions/checkout/compare/v3...v3.5.3 v3.5.2 What's Changed Fix: Use correct API url / endpoint in GHES by @fhammerl in actions/checkout#1289 based on #1286 by @1newsr Full Changelog: https://github.com/actions/checkout/compare/v3.5.1...v3.5.2 v3.5.1 What's Changed Improve checkout performance on Windows runners by upgrading @actions/github dependency by @BrettDong in actions/checkout#1246 New Contributors @BrettDong made their first contribution in actions/checkout#1246 ... (truncated) Changelog Sourced from actions/checkout's changelog. Changelog v4.0.0 Support fetching without the --progress option Update to node20 v3.6.0 Fix: Mark test scripts with Bash'isms to be run via Bash Add option to fetch tags even if fetch-depth > 0 v3.5.3 Fix: Checkout fail in self-hosted runners when faulty submodule are checked-in Fix typos found by codespell Add support for sparse checkouts v3.5.2 Fix api endpoint for GHES v3.5.1 Fix slow checkout on Windows v3.5.0 Add new public key for known_hosts v3.4.0 Upgrade codeql actions to v2 Upgrade dependencies Upgrade @actions/io v3.3.0 Implement branch list using callbacks from exec function Add in explicit reference to private checkout options [Fix comment typos (that got added in #770)](actions/checkout#1057) v3.2.0 Add GitHub Action to perform release Fix status badge Replace datadog/squid with ubuntu/squid Docker image Wrap pipeline commands for submoduleForeach in quotes Update @actions/io to 1.1.2 Upgrading version to 3.2.0 v3.1.0 Use @actions/core saveState and getState Add github-server-url input v3.0.2 Add input set-safe-directory v3.0.1 ... (truncated) Commits 3df4ab1 Release 4.0.0 (#1447) 8b5e8b7 Support fetching without the --progress option (#1067) 97a652b Update default runtime to node20 (#1436) See full diff in compare view Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase. Dependabot commands and options You can trigger Dependabot actions by commenting on this PR: @dependabot rebase will rebase this PR @dependabot recreate will recreate this PR, overwriting any edits that have been made to it @dependabot merge will merge this PR after your CI passes on it @dependabot squash and merge will squash and merge this PR after your CI passes on it @dependabot cancel merge will cancel a previously requested merge and block automerging @dependabot reopen will reopen this PR if it is closed @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself) @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself) View the full article
