Jose F Posted September 9, 2023 Posted September 9, 2023 Hello, I would like to have dual boot with a startup menu similar to GRUB on a PC, the idea is to have Android installed on the eMMC and Ubuntu on the NVMe, I am referring to an Orange Pi 5 Plus. Has anyone gotten it or is working on it? Thank you 0 Quote
ozacas Posted October 1, 2024 Posted October 1, 2024 Grub is available, but I've not tried it with both Android and Ubuntu dual boot as you describe. Note that there is also waydroid which may be worth considering to avoid the endless reboots - see But to come back to your original question, try this approach to setting up Grub on your OrangePi 5+ - it works well. Just be careful to choose an appropriate kernel for your requirements. You might have to enable USB2 support in the UEFI in order for the first boot to work (if you use a USB stick like I did) - see https://forum.armbian.com/topic/35168-generic-uefi-arm64-on-orangepi-5/ 0 Quote
