Device Tree missing network adapter definition?
As you can see the WAN-port/NIC registers fine with a label from the nanopi-r6c device tree
$ grep fe1c0000 /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb
grep: /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb: binary file matches
dmesg:
dmesg | grep fe1c0000
[    7.287277] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
[    7.287373] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    7.287377] rk_gmac-dwmac fe1c0000.ethernet: 	DWMAC4/5
[    7.287381] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[    7.287385] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[    7.287388] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[    7.287391] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[    7.287423] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[    7.287426] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    7.287430] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[    7.287433] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[    7.287437] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
However the LAN-port does not have such a label in dmesg output.
[    7.932846] pci 0003:31:00.0: [10ec:8125] type 00 class 0x020000
[    7.932902] pci 0003:31:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    7.932905] pci 0003:31:00.0: reg 0x10: [io  size 0x0100]
[    7.932958] pci 0003:31:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[    7.932993] pci 0003:31:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    7.933301] pci 0003:31:00.0: supports D1 D2
[    7.933303] pci 0003:31:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.948845] pci 0003:31:00.0: BAR 2: assigned [mem 0xf3200000-0xf320ffff 64bit]
[    7.948873] pci 0003:31:00.0: BAR 4: assigned [mem 0xf3210000-0xf3213fff 64bit]
[    7.948899] pci 0003:31:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.950294] r8125 0003:31:00.0: enabling device (0000 -> 0003)
[    7.967108] r8125 0003:31:00.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[    7.967112] r8125 0003:31:00.0 (unnamed net_device) (uninitialized): Random ether addr a2:83:9c:9c:cc:e8
