[Armbian build PR] - build(deps): bump tj-actions/changed-files from 38 to 39
Bumps tj-actions/changed-files from 38 to 39.
Release notes
Sourced from tj-actions/changed-files's releases.
v39
Changes in v39.0.1
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v39...v39.0.1
Changes in v39.0.0
What's Changed
Full Changelog: https://github.com/tj-actions/changed-files/compare/v38...v39.0.0
v38.2.2
What's Changed
... (truncated)
Changelog
Sourced from tj-actions/changed-files's changelog.
Changelog
39.0.1 - (2023-09-09)
🐛 Bug Fixes
  • Bug returning empty output for pull request close event (#1556) (246636f) - (Tonye Jack)
  • Raise error when the previous sha cannot be determined and since_last_remote_commit is true (#1554) (523e8b6) - (Tonye Jack)
  • Raise errors when unable to locate the previous commit in local history (#1551) (796ac2d) - (Tonye Jack)
🔄 Update
  • Update README.md (fe0fb71) - (Tonye Jack)
  • Update README.md (e60a7a9) - (Tonye Jack)
  • Updated README.md (#1548)
Co-authored-by: repo-ranger[bot] (534262e) - (tj-actions[bot])
  • Updated README.md (#1546)
Co-authored-by: renovate[bot] (89cb9ea) - (tj-actions[bot])
⚙️ Miscellaneous Tasks
  • Update check (#1555) (81bb5d8) - (Tonye Jack)
  • deps: Update dependency eslint to v8.49.0 (4a0a3c4) - (renovate[bot])
  • deps: Update dependency @​types/node to v20.6.0 (9dfd3f6) - (renovate[bot])
  • Update docs to site example (#1547) (673189f) - (Tonye Jack)
  • deps: Lock file maintenance (7113206) - (renovate[bot])
  • Add warning on valid output keys (#1544) (926a3fd) - (Tonye Jack)
  • deps: Update reviewdog/action-shellcheck action to v1.19 (de23f62) - (renovate[bot])
  • deps: Update dependency @​vercel/ncc to ^0.38.0 (afbabc4) - (renovate[bot])
  • deps: Update tj-actions/eslint-changed-files action to v21 (#1539) (eda0811) - (renovate[bot])
  • deps: Update dependency @​types/lodash to v4.14.198 (bda67fc) - (renovate[bot])
  • Update sync-release-version.yml (#1537) (5a5d398) - (Tonye Jack)
⬆️ Upgrades
  • Upgraded to v39 (#1536)
Co-authored-by: jackton1 jackton1@users.noreply.github.com (f699bde) - (tj-actions[bot])
39.0.0 - (2023-09-04)
🔄 Update
  • Update README.md (632c84d) - (Tonye Jack)
  • deps: Lock file maintenance (d68a666) - (renovate[bot])
... (truncated)
Commits
  • 246636f fix: bug returning empty output for pull request close event (#1556)
  • fe0fb71 Update README.md
  • e60a7a9 Update README.md
  • 81bb5d8 chore: update check (#1555)
  • 523e8b6 fix: raise error when the previous sha cannot be determined and since_last_re...
  • 4a0a3c4 chore(deps): update dependency eslint to v8.49.0
  • 9dfd3f6 chore(deps): update dependency @​types/node to v20.6.0
  • 796ac2d fix: raise errors when unable to locate the previous commit in local history ...
  • 534262e Updated README.md (#1548)
  • 673189f chore: Update docs to site example (#1547)
  • Additional commits viewable in compare view
Dependabot compatibility score
Dependabot will resolve any conflicts with this PR as long as you don't alter it yourself. You can also trigger a rebase manually by commenting @dependabot rebase.
Dependabot commands and options
You can trigger Dependabot actions by commenting on this PR:
  • @dependabot rebase will rebase this PR
  • @dependabot recreate will recreate this PR, overwriting any edits that have been made to it
  • @dependabot merge will merge this PR after your CI passes on it
  • @dependabot squash and merge will squash and merge this PR after your CI passes on it
  • @dependabot cancel merge will cancel a previously requested merge and block automerging
  • @dependabot reopen will reopen this PR if it is closed
  • @dependabot close will close this PR and stop Dependabot recreating it. You can achieve the same result by closing it manually
  • @dependabot show <dependency name> ignore conditions will show all of the ignore conditions of the specified dependency
  • @dependabot ignore this major version will close this PR and stop Dependabot creating any more for this major version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this minor version will close this PR and stop Dependabot creating any more for this minor version (unless you reopen the PR or upgrade to it yourself)
  • @dependabot ignore this dependency will close this PR and stop Dependabot creating any more for this dependency (unless you reopen the PR or upgrade to it yourself)
View the full article
