av4625 Posted September 18, 2023 Posted September 18, 2023 Should it be possible to take a working SD card out of one OrangePi Zero and put it in a new one? Same board and amount of RAM and everything. 0 Quote
Gunjan Gupta Posted September 18, 2023 Posted September 18, 2023 Yeah, I think that should work fine. Why, are you facing any issues when doing the same? 1 Quote
av4625 Posted September 19, 2023 Author Posted September 19, 2023 It wouldn’t boot. I put the SD card back in the original Pi and it was fine. I flashed a new SD card with the exact same image and it booted straight away. I have a script to setup new images, setup the new one the same as the old one and its working fine. just can’t seem to swap SD cards 0 Quote
Gunjan Gupta Posted September 19, 2023 Posted September 19, 2023 Its hard to help with just it wouldn't boot statement. What was the output from serial console. Or was there any output on the serial console? 0 Quote
av4625 Posted September 19, 2023 Author Posted September 19, 2023 I will have to check for you. It will be after the weekend as I need it for then and I have to take it out of an enclosure to get at the serial debug pins 0 Quote
