  On 9/23/2023 at 3:22 PM, 张军 said:
I did several tests and the problem was fixed after using the above device tree. But there seem to be some problems with the U-Boot.
Expand
Thanks for confirming I will raise a PR for this.
I used an SD card to boot and often the card would not move after the above print after reboot, it seems that the identified DRAM capacity is wrong.
Expand
Yes, modern u-boot detects the frequency sometimes wrong. I added a fix for this that reduced the frequency of the issue. Previously in my tests it was happening 50-80% of times on reboot. After integrating the fix the issue seems to have gone down to like 1 in 10 times or so. I will try to further tweak the fix and see if I can make it non-existent.
U-Boot SPL 2023.07.02-armbian (Sep 19 2023 - 18:28:54 +0000)
DRAM: 4096 MiB
Trying to boot from MMC1
Expand
This is now fixed. Updated u-boot should be available in beta repository within 24 hours.
@sliverb, this thread is about the software issue that was fixed.
The post you mention is mine and I think it's about a hardware issue. I have sent the board to the seller for testing and repair.
Thanks
@aoleynik
I wasnt sure if it was hadware related, though i suspected as much. Thanks for confirming. When i read your post, it matched the issues i saw 100%. (Part of me was hoping it was software related).
I'll reach out to the seller to see if they are open to helping me out.
Again, I appreciate your help on this.
